Will Goof Off Work On These Fiberglass Guages? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-11-2007, 01:02 PM   #1
Will Goof Off work on these fiberglass guages?
Hi, Great forums!
I am cleaning up a bathtub and I have a couple marks on my shower walls and was wondering how I could repair them. I was told Goof Off may work. Those little black marks in the photo above the hand rail (not the mildewy caulk below) are dug into the surface a bit. They are like little pock marks. Any idea what may work to fix them or at least cosmetically repair? Thanks a lot.
jojoma is offline   Reply With Quote
Old 08-11-2007, 03:31 PM   #2
Agent 000
SecretSquirrel's Avatar
Welcome to the forum jojoma!
Goof Off or Goo Gone both are great at removing adhesive residue, tar, sticky stuff, and so on. It (Goof off) *may* clean the divot in your fixture but it won't repair it. It appears that the towel bar holder is porcelain, is that correct? I found this product for fixing porcelain chips.
http://www.improvementscatalog.com/h...ip-repair.html
Please note that I have no experience with this product so I cannot vouch for its performance.
I Googled for "porcelain chip repair" and came up with a few repair products. You'll have to determine what's best for your needs. I hope this helps.
http://www.google.com/search?q=%22po...x=&startPage=1
SecretSquirrel is offline   Reply With Quote
Old 08-11-2007, 04:21 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
Are those "burnmarks" from a bather's cigarette ashes?
If so, they won't come up
I don't know of a fill-in off-hand
slickshift is offline   Reply With Quote
Old 08-11-2007, 07:07 PM   #4
Thanks for the reply. It's not porcelain, as in what a toilet is made out of. I checked out the porcelain repair product though and I liked the term "glaze" that was used. I think I need a fiberglass glaze. I think the marks have been there for a while but were covered up with something that matched the surrounding fiberglass. Perhaps paint.
Ranting about attic work IvoryRing Electrical 6 04-16-2008 08:21 AM
TrafficMaster grout f.y.i. denman Flooring 16 07-01-2007 04:07 PM
Using fiberglass filler on a balcony darsunt Painting 2 12-31-2006 09:13 PM
is this bad tiling work? garrick Flooring 17 09-27-2006 01:30 AM
