Why New Windows For Leaking Roof? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-03-2010, 04:48 PM   #1
Why new windows for leaking roof?
We just spent a ton of $ to have roof and siding repairs. The day after the repairs were finished, a huge rainstorm leaked water into our kitchen. The roofer did a water test and determined that the leak comes from two windows near but not at a point where the repairs were done. They gave us an estimate to install two new windows. They will not guarantee caulking.
Why do we have to buy brand new windows? Why can't we just re-install the ones we have? They are not broken, but the caulking is crummy.
Why didn't the roofer pick up on this before?
TerryJ2 is offline   Reply With Quote
Old 08-03-2010, 05:06 PM   #2
kwikfishron's Avatar
Rewards Points: 430
Was that leak there before? Was the contractor there to troubleshoot and fix “that leak”?
There is really no way to give you a accurate assessment without visuals.
Post a few pictures if you can, including a stand back shot of the wall from the window and up from the outside.
kwikfishron is offline   Reply With Quote
Old 08-04-2010, 06:06 AM   #3
They probably leaked because they were not properly flashed. Caulk is not enough. The top must have an aluminum drip cap that goes under the housewrap/siding, and over the top edge of the window. The sides and bottom must be covered with felt or adhesive membrane tape, all this after caulking the nailing fins. If they are now telling you they will charge to do the job right, I would be very upset. And they did not do it right the first time, what guarantee is there it will be done correctly the second.
Old 08-07-2010, 09:48 AM   #4
Home Performance
HomeSealed's Avatar
Rewards Points: 712
It very rare for windows themselves to be the source of a leak. The fact that you just had roofing and siding work done near there seems more than a little suspicious. Any siding work done around the windows should have incorporated the proper flashing, etc to seal that opening.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
EPDM - flat roof to sloped roof transition emtaboy Roofing/Siding 12 07-14-2010 12:12 AM
Need some help with roof - NO clue what to do, or how.. :( AdrianVall Roofing/Siding 7 04-22-2010 08:32 PM
Tile+Asphalt Roll Roof leaking - Opinion on what to do brookbphx Roofing/Siding 5 01-06-2009 06:51 AM
Addition and Roof Replacement lebeld Roofing/Siding 4 01-04-2009 06:11 PM
Windows before roof?? rodg2915 Roofing/Siding 8 03-08-2007 01:20 PM
