Why Do Drywall Joints Crack In Garages? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-04-2006, 01:19 AM   #1
Why do drywall joints crack in garages?
Alot of the taped joints in my garage are cracked. Both wall and ceiling. Is this common? Is it due to temperature? My house is only 3 years old. If I mud over them will they crack again? Is there anyway to prevent them from cracking? Any info would be greatly appreciated. THANKS.
Weelee929 is offline   Reply With Quote
Old 01-04-2006, 06:54 AM   #2
no way to prevent the cracking. your right temperature changes, moisture in the garage and foundation settleing. now that the house is a few years old i would mud over them.
THEBIGPUNN is offline   Reply With Quote
Old 01-05-2006, 08:12 PM   #3
johnh
most garages only have a tape coat applied, thus making them weak and easy to succumb to temperature changes. perform the block and finish coats and it should not occur again.
johnwhowe is offline   Reply With Quote
Old 01-06-2006, 07:30 AM   #4
Tired, Cold, and Damp
slickshift's Avatar
Retaping with the mesh tape helps also
slickshift is offline   Reply With Quote
Taping drywall joints - fiber glass mesh or paper? RickT Painting 25 04-20-2011 09:09 PM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 08:52 AM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 05:47 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
