Why 16" Centers - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-16-2008, 07:41 PM   #1
Why 16" centers
Why do we use 16" as centers, not 15" or 18"?
TNRocks is offline   Reply With Quote
Old 01-16-2008, 08:00 PM   #2
I have no idea, but I"m guessing that it has to do with drywall and plywood and stuff being multiples of 48". 16" + 16" + 16" = 48"
Hopefully I'm not a moron, but that's my thinking. lol
perpetual98 is offline   Reply With Quote
Old 01-16-2008, 08:15 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
LINK: http://www.contractortalk.com/showthread.php?p=229105
- Build Well -
Old 01-16-2008, 11:20 PM   #4
If you plan to install heavy shelves or large screeen TV on a certain wall, why not use 12" centers? Or, even 8" centers (1/2 of 16") and cut the fiberglass insulation sheets in 1/2. For stronger wall supports, going less then code is better...
Spike99 is offline   Reply With Quote
Old 01-17-2008, 06:16 AM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,070
Ayuh,......
If you were putting Live Elephants on that Shelf,.... Why not go with Inch,+ 1/2 Centers,......
Solid Wood..........
I've never seen a Wall with 16" centered wood that won't hold the Largest Shelf or TV.......
Bondo is online now   Reply With Quote
Old 01-17-2008, 08:03 AM   #6
Woodworker and Contractor
Kingfisher's Avatar
Rewards Points: 150
16" is fine for larger self/tv but if you want to make it easy on yourself and a row of 2x12 blocking for the brackets from the tv to screw into
Kingfisher is offline   Reply With Quote
Old 01-17-2008, 10:39 AM   #7
Rewards Points: 5,336
The use of 16" centers far pre-dates the use of most modern building materials except maybe wood lath(48"). I would think it has to do with the structural aspect of the spacing and the eventual need to standardize building materials for limiting waste.
Ron
Old 01-17-2008, 11:14 AM   #8
wfischer's Avatar
Lightbulb
16" centers are used because that's where the word "stud" is marked on most tape measures.
wfischer is offline   Reply With Quote
Old 01-17-2008, 11:26 AM   #9
On my one basement wall, I used 12" centers 2x3 studs, then installed shelves on it. With this "better then minimum code", I sleep much better at night. Works for me...
Old 01-17-2008, 12:02 PM   #10
Waste of money IMO
RYANINMICHIGAN is offline   Reply With Quote
Old 01-17-2008, 12:02 PM   #11
Plumbers and Sparky woudl hate you
16" OC wall framing erikkl2000 Building & Construction 11 11-16-2007 10:46 PM
Baluster Centers ?? sootybuttercup Carpentry 3 05-02-2007 08:36 PM
24 inch to 16 inch Centers dsearles Building & Construction 3 11-30-2005 10:20 PM
