Whole House Fan Won't Start - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-16-2012, 03:52 PM   #1
Whole house fan won't start
I just installed a Master Flow whole house fan (tandem fan model). When I press "On" using the remote control the lid opens like it is supposed to, but the fan does not come on. It continues to cycle the the lid for 3 times (open and closed) but the fans never start turning. After the third time opening the lid it turns itself off. Any suggestions? Is there a limit switch that needs to be set?
golfdad100 is offline   Reply With Quote
Old 06-16-2012, 04:34 PM   #2
It's a problem internal to the fan, internal to the remote, or internal to you (operator error). You are getting some power to the fan, at least enough to move the lid.
Check that the fan blades move freely.
Can you post operator/troubleshooting instructions? I couldn't readily find them. A schematic with parts list would be very useful.
Old 06-16-2012, 06:57 PM   #3
Too Short? Cut it Again!
Is there a thermal override. Some fans will shut down above a certain temperature so as not to draft a fire. You may be able to set this. Seems like the fins/vents should close too though.
Old 06-16-2012, 07:15 PM   #4
Tech support is closed on weekends. The manual doesn't have any troubleshooting info nor does it mention a thermal override.
Old 06-16-2012, 07:34 PM   #5
I just read the installation instructions online and hoped to find a troubleshooting section. No luck on the latter. I did see your remote has a timer function? Any chance you engaged that? I still don't see why the hood would open and close though. Wiring looked straight forward and again the hood is working just not your fan.
Old 06-18-2012, 07:16 AM   #6
Does the fan spin freely by hand? If you missed removing all packaging/tape to keep the fan locked in place during shipping the motor would overload when you try to start.
Roxerroneous is offline   Reply With Quote
Old 06-18-2012, 09:21 AM   #7
Thanks all. I checked to see if the fans rotated freely and they did, no packing material or locking pin. After I spun the fans by hand and pressed start the fans worked as they are supposed to!
Old 06-18-2012, 09:24 AM   #8
Rewards Points: 268
Just needed a jump start.
packer_rich is offline   Reply With Quote
Old 07-27-2015, 10:43 AM   #9
Rewards Points: 8
I have a similar problem - but my fan is about 15 years old. It has always worked fine in the past, but this Summer, when I turn it on the lid opens like it is supposed to, but the fan does not come on. It continues to cycle the the lid for 3 times (open and closed) but the fans never start turning. After the third time opening the lid it turns itself off.
When I go into the attic, I can "jump start" it by pushing the fan blades with a stick (don't want to lose any fingers) and it runs fine. Unfortunately, it has to be "jump started" every time!
Is it time for a new motor? It currently has a Franklin Electric model 4405030407 belt drive 115 volts and two different speeds. And where can I get a new motor from (in Central Jersey)?
Ronkster is offline   Reply With Quote
Old 07-27-2015, 11:17 AM   #10
Rewards Points: 6,034
Sounds like it could be the capacitor.
Entering your general location can help with answering a lot of times
Old 07-27-2015, 11:31 AM   #11
Try a good cleaning of the motor.
ron45 is offline   Reply With Quote
Old 07-27-2015, 12:12 PM   #12
Rewards Points: 8
ToolSeeker and ron45:
thanks for the quick replies!
I'll try the cleaning first, but if that doesn't work ... is the capacitor internal to the motor, can it be fixed (easily, cheaply) or am I looking at buying a new motor?
Thanks again!
Old 07-27-2015, 06:34 PM   #13
Rewards Points: 462
If you can post a picture of the unit I'm sure the guys here can identify if it has a cap and where it is. You have to get your comment count up to five before you can post a picture,
ChuckF. is online now   Reply With Quote
Old 07-27-2015, 07:51 PM   #14
It's almost certainly not internal but even if you find it remember it holds it's charge even after the wires are disconnected. Not expensive and a 20 minute fix.
Old 07-28-2015, 09:07 AM   #15
Rewards Points: 8
I tried cleaning the motor, even using the duster sprays for computers, but that didn't help
Weird wiring in house fdmillion Electrical 13 06-14-2013 06:49 PM
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 10:32 PM
Mast and weatherhead pulled from house, conflicting information from POCO subcontract SleepnZJ Electrical 1 11-02-2011 09:39 PM
Questions about jacking up house to replace rotted rim/sill SolidStateS15 Remodeling 10 03-22-2010 11:43 AM
Patio roof to house attachment question mikemobile Building & Construction 1 09-30-2008 07:51 AM
