-   General Discussion (http://www.diychatroom.com/f2/)
-   -   whole house fan (http://www.diychatroom.com/f2/whole-house-fan-105625/)
19mquinn79 05-26-2011 08:24 AM
whole house fan
hey guys,
i am in the market for a whole house fan. any advice? any brands you would recommend?
I read somewhere that it is important to buy one with a belt drive. anyone agree?
thanks!!
Ron6519 05-26-2011 08:34 AM
Originally Posted by 19mquinn79 (Post 655182)
hey guys,
thanks!!
While waiting for reponses, do a forum search on previous fan discussions.
Ron
19mquinn79 05-26-2011 10:52 AM
Ron
haven't had much luck with my search.
Ron6519 05-26-2011 03:09 PM
Provide some attic details. How tall? Gable space to install fan? Common area to install attic vent?
Size of the house? Attic access? Type of roof venting?
Ron
D-rock 05-26-2011 06:41 PM
I installed a non-belt driven style fan in my upstairs hallway five years ago. Purchased from the Grainger company, works great, no troubles. I don't belive you need much attic space to use one, a couple feet would work, just make sure you have a good attic ridge vent for air flow out
diyorpay 05-26-2011 07:01 PM
Some considerations:
1. Don't ever turn on if downstairs windows/sliding glass doors are not open first. Minor implosion could crack sheet rock. (If putting in a switch in upper hallway, put it up high, away from small children.)
2. A multi speed unit is better if you can find it. Pay attention to sone levels. Balance unit. Sandwich in some foam as a shock absorber between rafters and fan.
3. Don't expect miracles. It works great to cool down house in early evening, 1 degree at a time, as daytime heat subsides. Won't help humidity/may make it worse. Then turn on A/C.
4. Also pulls in dirt and pollen. A filter won't work. Someone will dust more often (and complain/curse?).
5. Insulate/seal well in winter or cold attic air will get you.
