-   -   Where to get 2" to 1-1/4" hose adapter for vac? (http://www.diychatroom.com/f2/where-get-2-1-1-4-hose-adapter-vac-192473/)
mikegp 12-22-2013 11:34 AM
Looking everywhere and having trouble finding it. I found some universal ones with step downs, but they have mixed reviews about what sizes they actually fit. Searching is tough because the numbers can be written in so many ways. Figured I'd ask here first. Thanks for any help.
gregzoll 12-22-2013 12:13 PM
If this is for a Central Vac. system, they use standard whit PVC. You just need to get the adapter in the plumbing section a your local hardware store, or plumbing supply house.
mikegp 12-22-2013 12:19 PM
It's for a dustless drywall sanding setup. Oneida dust deputy to Marshalltown sander and shop vac.
Windows on Wash 12-24-2013 04:07 PM
Most Big Box Hardware stores have the stepped adapters.
http://www.amazon.com/Big-Horn-11269...op+vac+adapter
mikegp 12-25-2013 02:49 PM
Thanks. I ended up ordering two different ones that say they are 2.25 to 1.25. Figure one will work or at least be close enough that I can tape it. I don't trust the step ones, but thanks.
Scottg 12-28-2013 10:27 PM
Some woodworking suppliers like Woodcraft or Rockler may have the right attachments.
MT Stringer 12-29-2013 04:45 PM
3 Attachment(s)
Adapters are a real pain. Some list the size as OD...some ID...other just choose a random size. I have in the past taped some, cut slices in others with the band saw and used a heat gun. Lastly, I have used a belt sander on the outside of a couple of pieces to thin em down a smidgeon.
Good luck.
Mike
mikegp 01-02-2014 07:24 AM
I received two of the 4 I ordered and made them work by adding some rubber bands as gaskets. Working well so far. I'm hoping the other two are a closer fit when they arrive, but not getting my hopes up.
MTStringer, nice setup. How do you like the Dust Deputy? Seems to be removing 99% of my drywall dust before it gets to the vac.
Also, I have ShopVac that looks identical to yours except for the color. It didn't come with a cap for the exhaust port. What purpose does that serve?
MT Stringer 01-03-2014 01:41 PM
Mike, the Dust Deputy works great. Very little makes it into the shop vac. I don't have a clue on the cap. I have never taken it off. Maybe it is for wet vac service,,,just guessing.
mikegp 01-05-2014 09:17 PM
Never mind, looked again and my vac is different.
