Where To Get 1" Steel Pipe Threaded - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-27-2011, 11:18 AM   #1
Where to get 1" steel pipe threaded
I am making a pull up bar and needed to cut one end of 1" steel pipe that I got from home depot but now I want to thread the end
Where can I get this done?
pjoseph is offline   Reply With Quote
Old 07-27-2011, 11:29 AM   #2
Rewards Points: 6,652
A Plumber could do it, or check to see if your local Ace Hardware can do it. Also, you can rent a pipe threader from places like Home Depot, and do it yourself.
Old 07-27-2011, 11:31 AM   #3
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 682
Normally, I have HD cut and thread the pipe when I buy it. Like was said above, most Ace Hardware stores can do it. Just call first to make sure that particular Ace has a pipe threader.
hyunelan2 is offline   Reply With Quote
Old 07-27-2011, 05:16 PM   #4
Rewards Points: 5,336
The Home Depots around here cut and thread pipe on premises.
Ron
B. Franklin 1759
Old 07-29-2011, 12:20 PM   #5
I ask the impossible!
Rewards Points: 640
I've gone back in to HD with pipe I had already bought there and had it cut and threaded, just go in and let the greeter know what you're doing and then go to the plumbing department, then go back out by the greeter. One time the greeter just said he'd still be there and recognize me, another time they gave me some sort of sticker.
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Qs about the 1/2"dia brass pipe we bought smoochas Plumbing 10 02-21-2011 10:23 AM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 02:05 AM
Backpitched Cast Iron Pipe in Basement....uggh.. apunaha23 Plumbing 5 02-02-2011 02:42 AM
Bernoulli's Principle, increase 3/4" pipe to 1-1/4" or 1-1/2" copper ChrisDIY Plumbing 14 09-18-2010 10:49 PM
Furnace Venting Requirments jamiedolan HVAC 9 11-18-2008 06:40 PM
