-   -   Where to find codes? (http://www.diychatroom.com/f2/where-find-codes-165920/)
fabian 12-08-2012 12:56 PM
Hello! I am getting motivation and planning to finish my basement. I will do the work myself as take my time with it. My question where do I find out the codes to do the work properly? Where can I go to get answers as far as far a receptical being how far from a corner. How many do you need for a room. How high off the floor. Questions like framing and just basic questions. I want to do it right so the inspection is a smooth breeze. Is there a book? Library? Internet? Is it free? I can't seem to find a "rule book" searched all over google.
Bondo 12-08-2012 03:44 PM
Ayuh,.... Is this in London England,..??
Paris France,..??
Perth Australia,..??
Port o Prince Haiti,..??
Columbus Ohio,..??
joecaption 12-08-2012 03:56 PM
Go back and add your location to your profile.
fabian 12-08-2012 04:20 PM
South river, new jersey
Daniel Holzman 12-08-2012 04:34 PM
Check with your local code enforcement official, usually the building inspector. They will have all the codes, and additional information regarding local regulations.
fabian 12-08-2012 04:35 PM
I know Daniel. Thanks for the reply. I know they will know but is there a manual of some kind. I rather not call him every time I have a question.
ToolSeeker 12-08-2012 06:01 PM
Yes where I am the local library has code books. And the internet can probably help. Not to be smart but if you are not familiar with codes to read them can be quite confusing at times even for someone who deals with with regularly.
rusty baker 12-08-2012 08:11 PM
And many of them differ from common sense.
Gary in WA 12-08-2012 08:26 PM
This will get you started; http://www.reedconstructiondata.com/...es/new-jersey/
Gary
jklingel 12-08-2012 09:09 PM
And bear in mind that codes are the minimum acceptable design, so go a tad over on insulation, etc. Have fun.
fabian 12-09-2012 06:39 AM
Thank you.
gwilkrrs 12-09-2012 07:14 AM
holy smokes! where and how did you find that link? i cantfind minefoe carroll county maryland can you? thanks
user1007 12-09-2012 10:27 AM
Bet there is one near you. It is usually a big, underfunded building, hopefully up to code. It is full of smelly books and sometimes smelly kids being read stories. Or hippy era chicks playing soft guitar and doing puppets.
In a corner somewhere is either a person or two or an entire staff of reference librarians that will help you find what you need. Anywhere. I admit to using them when lazy or if I need access to things I cannot get personally. Most can even do things like notarize documents for free. Snarly folks though that can only be bribed to do you any good with Christmas cookies.
The historical archive people in most libraries cannot be bribed. If you need drawings or photos. Find out when they will be out for lunch. Don't be crass. Put the drawings and photos back for the next person.
Bring photocopy money or a blank thumbdrive. Most don't have money to make many copies of things for free.
MarkusAIC 12-09-2012 11:46 AM
You need to call or local Building Dept or go on their website and see 'which' Code they are using.
Larger municipalities typically have their own set of building codes (based on the standard ones with variations) while smaller municipalities typically have adopted a version of one of the standard Codes.
At this point in time, many smaller Muni's throughout the country have adopted some version of the IRC (International Residential Code, 2003, 2006, etc). However, there are still some Muni's that are under the older BOCA or other Code standards.
Find out which Code your Muni uses and go from there.
Some Muni's have their adopted Code listed on their website, some don't. Some Code versions can be found online with research, others need to be purchased.
If needed go to iccsafe.org.
Code books are not as easy or simple to read as many DIY or novices would like. Requirements vary for different occupancy and construction types. When figuring out requirements it is important to make sure you are looking under the right section for the type of structure and occupancy you have.
As I have to tell clients all to often, "The Code is not a ceiling to reach but a floor to work up from".
As someone else mentioned the Code is a minimum standard not a maximum. In many respects following Code is more than sufficient. However, that doesn't mean you shouldn't consider improving on it for your particular situation as relevant.
fabian 12-09-2012 08:37 PM
Yes Markus, I already completely understood that codes is a minimum reference point. My question was where to find my answers to certain questions. I appreciate the feedback and will look into those u mentioned.
