Where Do I Find This Part? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-05-2011, 05:23 PM   #1
Where do I find this part?
Picked up a free Weedwhacker, this part is stripped. I can't find it anywhere on the interweb.
Looked the most obvious places. anyone have an idea on where to get this sprocket?
Its a Ryobi C430 which is the same as any/most homelite 30CC engine.
Home Cheap-o special
http://www2.snapfish.com/snapfish/sl...NAME=snapfish/
iamsaws is offline   Reply With Quote
Old 06-05-2011, 05:44 PM   #2
found this-
http://www.ereplacementparts.com/ryo...33_129987.html
Any idea why the one part needed is not listed?
Old 06-05-2011, 06:15 PM   #3
Rewards Points: 266
Possibly it is part of the larger assembly which also doesn't seem to be labeled. I wouldn't give up without checking e-bay first. Also see if you can get a Ryobi CSR on the phone to help you out.
Jim F is offline   Reply With Quote
Old 06-05-2011, 06:22 PM   #4
thanks! It actually starts and runs perfect, but once it gets hot the sprocket is
worn so it throws the belt. Ill find it. Ill call Ryobi in the morning. Anyone ever deal with them?
Old 06-05-2011, 07:24 PM   #5
Rewards Points: 6,652
Any local lawn mower/lawn care equipment repair shop should be able to get it for you, or have on hand. If you have a farm supply store that sells and repairs small equipment check with them.
Old 06-06-2011, 04:08 AM   #6
You should consult with professionals. They will help you.
sudarshan is offline   Reply With Quote
Need help find a shower model Gege Plumbing 2 11-01-2009 01:09 PM
Aprilaire part 4851 Blower Activation Relay glassr HVAC 0 09-25-2009 04:57 PM
Where can I find good contractor and building material suppliers? denniis Off Topic 5 03-10-2009 10:27 AM
Can't find fuse... Please help!!! keithstef2005 HVAC 3 01-03-2007 11:21 PM
find switch to control outdoor light fixture CaymanAg Electrical 1 07-10-2005 09:43 PM
