Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 06-03-2011, 07:21 PM   #1
Where could I find this?
I'm looking for a cable tie base like this:
The only problem is that I need them to NOT have the adhesive on the back. It isn't strong enough to hold for what I'm doing, and either plan on replacing it with a stronger adhesive, or glue.
Thanks for any help.
Evyllchyld is offline   Reply With Quote
Old 06-03-2011, 07:35 PM   #2
Electrical Contractor
Radio shack or the box stores.
The ones I use have the adhesive, but also have screw holes like the one you show.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 06-03-2011, 08:05 PM   #3
Missouri Bound's Avatar
I think it's made by Gardner Bender. Their website may help you find a distributor.
Old 06-03-2011, 10:13 PM   #4
I'm looking for ones without adhesive. I've found plenty with adhesive. I can't use a screw for what I'm using them for.
Thanks, again.
Old 06-03-2011, 10:17 PM   #5
Average Joe/ex-Navy IC3
gregzoll's Avatar
Thanks, again.
That is why you use doublestick or carpet tape. Just get the above fasteners and some doublestick.
Old 06-03-2011, 10:50 PM   #6
I"m sure they are available with and without. And as far as the adhesive goes, just don't peel off the paper if you don't want it sticky.
Where can I find good contractor and building material suppliers? geordge Green Home Improvement 3 03-11-2009 12:11 PM
Where can I find good contractor and building material suppliers? denniis Off Topic 5 03-10-2009 10:27 AM
need to find wall switch remote..does that exist? tarheelblue Electrical 7 09-05-2008 06:51 AM
find switch to control outdoor light fixture CaymanAg Electrical 1 07-10-2005 09:43 PM
New to find a contractor - Northern NJ jhirsch1 Building & Construction 2 03-23-2005 09:24 PM
