Where Can I Order Dual-pane Glass? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-15-2008, 10:22 PM   #1
Learning by Doing
Leah Frances's Avatar
Where can I order dual-pane glass?
I've been rebuilding an old exterior door and am ready to put some glass back in the openings and I started thinking. Why put the old single pane glass back in when I could put a piece of dual pane glass in it's place? I've got plenty of thickness to work with.
Where can I/can I order this sort of thing to size?
Thoughts?
LFW
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 12-15-2008, 10:28 PM   #2
Registered User
Termite's Avatar
Any glass company in your town can make them or have them made for you. Don't waste your time at the hardware store or the box stores, because all they'd be is a middleman.
Old 12-15-2008, 10:29 PM   #3
Registered User
Termite's Avatar
Something to think about with divided light glass units...The perimeter of them has a rubbery goopy black gasket that is about 1/2" thick when looking at the panes of glass. So, you'd need to account for that when trimming the door so that part will be covered up.
Old 12-16-2008, 06:09 AM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
If you're putting them in a door, they really should be made from tempered glass or safety sheet.
Old 12-16-2008, 08:37 AM   #5
Registered User
Termite's Avatar
Very true, I should've mentioned that. Any glass in a door has to be tempered. That should be no obstacle, but will take a couple weeks in most cases. They have to cut it to size, temper it, then make the units.
Old 12-16-2008, 09:26 AM   #6
Rewards Points: 22
Would dual pane glass help or does it need to be filled with gas? Do the glass companies fill these with gas when they make them? Don't mean to high jack, just trying to clarify for others and myself.
ponch37300 is offline   Reply With Quote
Old 12-16-2008, 10:20 AM   #7
Registered User
Termite's Avatar
Dual pane glass units are usually filled with argon gas.
Old 12-16-2008, 11:46 AM   #8
Learning by Doing
Thanks for the info - I will take tempering the glass and the gasket into account. I guess I'll get on the horn to glass shops.
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
"Defogging" double-pane windows .... a gimmick?? alexz General DIY Discussions 133 03-10-2010 12:35 PM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 02:41 PM
Soundproof Windows BlueJello General DIY Discussions 3 11-30-2007 05:34 PM
What makes a quiet window? Badfish740 Building & Construction 8 09-30-2007 10:22 AM
