Where Can I Get A Single Clapboard? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-07-2012, 10:15 AM   #1
Rewards Points: 163
Where can I get a single clapboard?
Hi,
One of my siding clapboards is rotten. So I need to get a clapboard to replace it. But I could find them only in bundles of 10, which I don't need. Are clapboards available at all not in bundles?
Thanks you very much.
dpreznik is offline   Reply With Quote
Old 05-07-2012, 10:31 AM   #2
Rewards Points: 13,712
Just a guess, is this board at the bottom of a wall that's do close to the ground?
What type wood is it your looking for?
Any lumber yard I've been to, Lowes HD all have single pieces.
If it is to close to the ground with a few pictures we may be able to suggest a better way to repair this so it would not happen again.
dpreznik (05-07-2012)
Old 05-07-2012, 10:32 AM   #3
kwikfishron's Avatar
Rewards Points: 586
Go to a real lumberyard, if they stock that profile you should be able to buy just 1' of a piece if that's all you need.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Old 05-07-2012, 10:37 AM   #4
Rewards Points: 163
Thank you for your answer. No, it is not too close to the ground, it is just a wall that has no covering over it.
I looked at Lowes and two real lumber yards, and they don't sell single pieces...
Old 05-07-2012, 10:41 AM   #5
Sure some lazy stocker just did not cut off the bands? I've been in at least 10 differant Lowes and have never once seen siding not sold by the piece.
Old 05-07-2012, 10:43 AM   #6
Rewards Points: 163
Hmmm, I will try again. Thanks.
Old 05-07-2012, 10:46 AM   #7
Unless you have some odd ball profile they should have Cedar, pine, and Hardee plank.
Old 05-07-2012, 10:48 AM   #8
Rewards Points: 163
They do have what I need, but in bundles...
Old 05-07-2012, 03:37 PM   #9
In a little over my head
Rewards Points: 706
I don't know where you're located, but around here HD and the local lumberyard sell it by the piece.
ratherbefishing is offline   Reply With Quote
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-08-2011 11:00 PM
Double Hung vs Single Hung CZSteve Remodeling 0 11-08-2010 07:29 AM
3 way, 4 way, Single Pole/3-Way Combinations slash5bmw Electrical 5 06-22-2010 07:21 AM
Want to add a single phase Subpanel to three Phase Main meglomachinist Electrical 19 09-10-2009 03:46 PM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 01:11 AM
