Where Can I Find Out What My Light Switches Contol?? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-30-2011, 01:17 PM   #1
Where can I find out what my light switches contol??
Sorry if this is a stupid question, this is my first post here! I just moved into my first home and there are like 18 light switches that seem to not control anything! I've tested the outlets and that didn't work. Where can I find out? Thanks!
Alexzandra is offline   Reply With Quote
Old 11-30-2011, 02:53 PM   #2
biggles's Avatar
wall swiches rarely control wall sockets.. mostly over head lights...cabinet lights...outdoor lights.if you have ceiling fans and nothing happen when you hit a wall switch in a room check the fan pull chains might all be clicked off.
Old 11-30-2011, 03:34 PM   #3
Old School
Willie T's Avatar
Go make sure your breakers are all "ON".
Willie T
Old 11-30-2011, 03:42 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Are a lot of bulbs burned out?
Old 11-30-2011, 06:19 PM   #5
joed's Avatar
Rewards Points: 13,740
IF there are no overhead lights in the room the wall switches likely control receptacles or half receptacles. If someone change those half switched receptacles in the past it is possible the switches no longer work. Half switched receptacles require the tab to be broken on the hot side. If the tab is left intact then the switch will no longer control anything.
Old 11-30-2011, 06:30 PM   #6
Rewards Points: 5,336
As Bud said, check the bulbs first. Make sure they all work, then turn on a switch and track it down. Many of these might be exterior lights.
Many houses have switches that control outlets. When I bought my house, all the bedrooms and the living room had these in place.
Ron
B. Franklin 1759
Old 11-30-2011, 08:08 PM   #7
Rewards Points: 14,312
As some of the other posters sort of emplyed, it's possible that a duplex outlet can 1 side have power full time and the other 1/2 be on a switch.
Very common so as you walk into a bedroom or living room to be able to turn on a ligh without having to walk across a dark room to find a light.
Old 11-30-2011, 08:09 PM   #8
What do you mean the tab would be broken? Like I said, I'm completely new at this...
Old 11-30-2011, 08:32 PM   #9
On the side of the outlet there's a metal tab that connects the top and bottom receptacles. If you break the tab off they are separated and can be wired individually.
One can be controlled by a switch while the other is constantly hot. So you need to test both when you turn the switch on or off.
Ron
B. Franklin 1759
Old 12-01-2011, 07:07 AM   #10
Rewards Points: 152
Keep in mind too that some of the switches may be 3 or 4-way, so it is possible that two, three, or more switches may control a common light or receptacle(s). For this reason, you want to have a maximum of two people involved in the process; one with a meter, tester, whatever, and one operating the switches.
Old 12-01-2011, 07:33 AM   #11
I just plug a radio into the receptacle. This way you can work alone if no one is around.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
Willie T (12-01-2011)
Old 12-01-2011, 07:44 AM   #12
And if you use a radio make sure it's not a battery back up radio, unless you take the batterys out. It will keep working other wise. Been there done that.
Old 12-01-2011, 08:10 AM   #13
You mean like being in the basement, flipping off breakers in a 42 circuit box and the radio never goes off. You mean like that?
Ron
B. Franklin 1759
Old 12-01-2011, 09:43 AM   #14
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
How old is your house? Has it ever been re-sided? I have a switch that does nothing because the PO had the house re-sided and had an outside light removed.
I have another switch that I have no idea what does.... the PO doesn't even know (She lived there for 30 years).
CoconutPete is offline   Reply With Quote
Old 12-01-2011, 09:53 AM   #15
Ironlight's Avatar
In our previous house, which had been subject to numerous renovations before we moved in, there was a bank of five switches that did absolutely nothing at all. It was impressive.
Ironlight is offline   Reply With Quote
Installing switches for fan and light on one electrical line puhitom Electrical 2 08-26-2011 04:50 AM
replaceing wall plug and light switches niondion Electrical 1 06-11-2011 08:52 PM
4 switches control 1 light, power at light thinksnowjob Electrical 5 05-19-2011 08:55 PM
Two Switches, an outdoor light, and a wall plug MichaelT Electrical 1 03-06-2011 05:17 PM
adding an additional light to 2 3-way switches basement_guy Electrical 10 07-20-2008 09:23 AM
