Where Can I Buy A Small Cylindrical Foam Padding? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-02-2013, 02:36 PM   #1
Rewards Points: 129
Where can I buy a small cylindrical foam padding?
This is a pull-up bar for the doorway
See the cross-hatched bicycle handle thing?
It's to prevent the door sill paint from scuffing.
Mine just has a foam tube there.
I can use either style above.
How can I fabricate or Google search something generic for a few bucks?
What would it even be called?
Mathlete is offline   Reply With Quote
The Following User Says Thank You to Mathlete For This Useful Post:
PaliBob (11-02-2013)
Old 11-02-2013, 03:18 PM   #2
K&B Designer
Live_Oak's Avatar
Any box store will sell pipe insulation in a few different sizes. Can't tell your size, but it's certainly cheap enough to work for you.
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
Old 11-02-2013, 03:46 PM   #3
Rewards Points: 129
That looks like it would work. They only sell this in 6' length. Wasteful.
http://www.ebay.com/sch/i.html?_saca...lation&_sop=15
Old 11-02-2013, 04:48 PM   #4
Rewards Points: 6,652
You do know that you can use the Foam pipe insulation anywhere. Most times people will take an old hose, cut it for putting over areas that will rub against something, then wrap tape.
Old 11-03-2013, 09:01 AM   #5
In a little over my head
Rewards Points: 706
Bicycle or motorcycle hand grips. What is the OD of the tubing?
ratherbefishing is offline   Reply With Quote
Old 11-03-2013, 10:22 AM   #6
Rewards Points: 166
Search for "foam handlebar grips". I just did that and found several companies that sell a wide variety of foam tubing in different sizes and colors.
You can also usually buy handle bar grips inexpensively in the bicycle section of any sporting goods store.
dftc is offline   Reply With Quote
Scissor trusses, Foam and FG zambo Insulation 2 11-15-2012 06:15 AM
Thickness of XPS Foam Corey47 Insulation 5 10-10-2012 09:57 PM
How to add padding to a Kendo "men" that is too big mgp roofing How To Guides 0 10-04-2012 01:00 AM
B-12 Chemtool versus SeaFoam DrHicks Automotive Repairs 16 10-01-2012 08:57 PM
Insulating Existing Garage with Polyiso Foam Board saxman2u Insulation 6 09-18-2012 01:45 PM
