Where To Buy Heat Treated Plywood Or OSB And Lumber? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-19-2009, 07:52 PM   #1
Where to buy heat treated Plywood or OSB and lumber?
In the South East Wisconsin area, in and around Waukesha and Milwaukee, where can I get heat treated Plywood or OSB and heat treated lumber?
The products must have the HT tag/stamp on them.
At Menards, they say their CDX plywood is heat treated but it doesn't have the tag/stamp on it. They have lumber 2x4 that says HT only on the cross section. I need the lumber to say HT on the sides.
This is for making an export crate to comply with export regulations, which is why I need a stamp or printed on the products.
Spud is offline   Reply With Quote
Old 10-19-2009, 08:19 PM   #2
Rewards Points: 1,014
Heat treated as in kiln dried?, or heat treated as in fire retardant lumber?
Anti-wingnut is offline   Reply With Quote
Old 10-19-2009, 09:03 PM   #3
I think it is klin dried.
Here is the explanation.
The international export standard, ISPM 15, requires that all wood packaging material be heat-treated at a core temperature of 56 degrees Celsius for a minimum of 30 minutes.
Here is a tag with HT
http://atlaswoodproducts.files.wordp.../dsc001191.jpg
Old 10-20-2009, 07:49 AM   #4
joed's Avatar
Rewards Points: 13,706
It's to kill insects.
Old 10-20-2009, 10:17 PM   #5
Registered User
Termite's Avatar
For export/import purposes, the HT designation isn't the same as kiln-drying.
Spud, try an actual lumberyard. Not a box store, but somewhere that sells nothing but lumber. The HT grade stamp availability may be hit and miss though, you'll just need to call around.
Old 10-21-2009, 09:49 PM   #6
rwa
rwa's Avatar
Rewards Points: 43
http://connerindustries3-px.avxtrk.com/
check here
rwa is offline   Reply With Quote
