-   -   Where to buy heat treated Plywood or OSB and lumber? (http://www.diychatroom.com/f2/where-buy-heat-treated-plywood-osb-lumber-55543/)
Spud 10-19-2009 08:52 PM
In the South East Wisconsin area, in and around Waukesha and Milwaukee, where can I get heat treated Plywood or OSB and heat treated lumber?
The products must have the HT tag/stamp on them.
At Menards, they say their CDX plywood is heat treated but it doesn't have the tag/stamp on it. They have lumber 2x4 that says HT only on the cross section. I need the lumber to say HT on the sides.
This is for making an export crate to comply with export regulations, which is why I need a stamp or printed on the products.
Anti-wingnut 10-19-2009 09:19 PM
Heat treated as in kiln dried?, or heat treated as in fire retardant lumber?
Spud 10-19-2009 10:03 PM
I think it is klin dried.
Here is the explanation.
The international export standard, ISPM 15, requires that all wood packaging material be heat-treated at a core temperature of 56 degrees Celsius for a minimum of 30 minutes.
Here is a tag with HT
http://atlaswoodproducts.files.wordp.../dsc001191.jpg
joed 10-20-2009 08:49 AM
It's to kill insects.
Termite 10-20-2009 11:17 PM
For export/import purposes, the HT designation isn't the same as kiln-drying.
Spud, try an actual lumberyard. Not a box store, but somewhere that sells nothing but lumber. The HT grade stamp availability may be hit and miss though, you'll just need to call around.
rwa 10-21-2009 10:49 PM
http://connerindustries3-px.avxtrk.com/
check here
