Where To Buy Greenhouse Glass Sheets? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-27-2014, 09:19 AM   #1
Where to buy greenhouse glass sheets?
Hi Folks
Due to the recent bad weather, one of my glass sheets on my greenhouse cracked. It is not ‘proper’ glass, so could anybody tell me the proper name for it? Where could I buy a sheet for a reasonable price on line? Are the sizes standard?
Thanks in advance for your responses.
geek84 is offline   Reply With Quote
Old 02-27-2014, 09:46 AM   #2
Rewards Points: 14,300
No one knows where on the planet you are because there's no location in your profile.
Easy to fix just go to quick links to edit.
Got a picture?
Any hardware, Lowes, Home Depot, Menards will have Plexiglas and some Lexan in stock.
Plexiglas is cheaper but tends to yellow and craze over time.
Old 02-27-2014, 10:00 AM   #3
K&B Designer
Live_Oak's Avatar
Grower's Supply The material can be anything from fiberglass rolls to triple wall polycarbonate. You've got to do the research to find the best choice for your climate and pocketbook. The more expensive stuff does tend to resist UV degradation longer though.
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
Old 02-27-2014, 10:06 AM   #4
Rewards Points: 6,652
You can also go to your local Glass Shop. They would have the ovens to heat the material for forming any curve that is needed.
Post a picture of the Greenhouse.
Old 02-27-2014, 10:07 AM   #5
Hi Folks
Thanks for your replies. I live in West Midlands - UK.
Old 02-27-2014, 12:13 PM   #6
Do you know who built the green house.?
ron45 is offline   Reply With Quote
Old 02-27-2014, 05:47 PM   #7
Oso954's Avatar
Rewards Points: 1,628
You can try these folks.
http://www.theplasticpeople.co.uk/gr...g-c-98_65.html
Oso954 is offline   Reply With Quote
Old 02-27-2014, 06:36 PM   #8
Rewards Points: 2,646
You can read up on your options here:
http://twogreenthumbs.hubpages.com/h...se-glass-guide
SPS-1 is offline   Reply With Quote
Old 02-28-2014, 04:08 AM   #9
Rewards Points: 12
i think they sell that stuffs at amazon.com
atun willis is offline   Reply With Quote
greenhouse glass roof seal? wt timberworks Roofing/Siding 6 07-12-2015 08:42 AM
What can I use to adhere mosaic glass tile (sheets) to particleboard? DIYLuvr Tiling, ceramics, marble 9 01-11-2011 12:30 PM
Glass on greenhouse roof Flavio Building & Construction 16 07-15-2010 07:37 AM
"Defogging" double-pane windows .... a gimmick?? alexz General DIY Discussions 133 03-10-2010 12:35 PM
glass tile wall sheets meganc Flooring 0 12-15-2009 05:12 PM
