What's Up With My Well? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-08-2011, 10:17 AM   #1
What's up with my well?
Why won't the bladder take on any water? More importantly, how do I fix it? It's only a year old. Pressure switch and control box are new. The P.S. is a 30-50, bladder pressure is 28 psi, can't get inline pressure over 40, therefore the pump won't shut off automatically.
Dwoodsmith is offline   Reply With Quote
Old 02-08-2011, 10:58 AM   #2
if it drains down after cut off a hole in water line between pump and press tank. just replaced mine
The older I get the better I was
Old 02-08-2011, 11:05 AM   #3
Experienced
Jackofall1's Avatar
Sounds like the line is frozen between the pump head and the bladder.
Mark
Old 02-08-2011, 11:43 AM   #4
joed's Avatar
Rewards Points: 12,388
Submersible pump? Jet pump? Pump in house at tank or out at well? Is any water coming out?
Old 02-08-2011, 11:46 AM   #5
The three feet of line between the submersible pump and the tank is clearly visible inside the pumphouse here in N. Fla where the outside temp. is a chilly, but not freezing 50 degrees. Any other theories?
Old 02-08-2011, 12:05 PM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,030
Any other theories?
Ayuh,... An air leak on the suction side...
Old 02-08-2011, 12:11 PM   #7
Where and how do I find out?
Old 02-08-2011, 02:03 PM   #8
joed's Avatar
No suction air leak if the pump is submersible, unless the well has run dry. The pump is always under water.
Is the pump pumping any water? If it is then the pump could be bad. If the impellars have been worn then it won't be able to build pressure. Have you noticed any particles in water recently? Black stuff could have been the impellars grinding away.
Could be a leak in the pressure line up from the well. If you open the well cap and listen while the pump is running you should hear the water squirting if there is a leak.
Old 02-08-2011, 03:04 PM   #9
I'm really hoping to find a problem to fix above ground. Oh well, sometimes things are what they are whether or not we want to believe it.
