Whats The Proper Name For This - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-19-2009, 02:11 PM   #1
K.M.G's Avatar
Rewards Points: 113
Whats the proper name for this
Hi
I'm not sure what this overhead bunker above the shower/tub is called
I didn't take many pictures when I had the Drywall off and can't figure out how it was build now.
I Don't know the proper name,So I can even look for plans on how they are built.
This is what it looked like before
Where I'm now(LOST)
On this side I have two 1x6's,but the other 1
Also the wood wasn't sitting stright on with the roof joist all the wall down it seems so i build it like it was,should the 1x6's be dead on..I just hope it holds.
I'm desperately trying to finish rebuilding the front half
I hope someone can point me into the right direction
I don't even know what these bulk heads are good for
K.M.G is offline   Reply With Quote
Old 11-19-2009, 02:13 PM   #2
K.M.G's Avatar
Rewards Points: 113
More pictures
What it look like with the Drywall stripped
Old 11-19-2009, 02:17 PM   #3
Remodeling Contractor
these soffits are built over a tub to lower the ceiling which keeps more warm air closer to the tub. Nothing critical with structure as long as it does not fall down. Just there to hold the drywall up. In some cases it may be used to also conceal duct work going to upper floors.
Old 11-19-2009, 04:30 PM   #4
Might want to have someone look at the insulation and air flow up along the soffits. Doesn't look like much insulation and it appears the trusses don't have an energy heel on them. Looked like moisture buildup in some of the pics.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 11-19-2009, 07:19 PM   #5
Registered User
Rewards Points: 5,482
I would also suggest to have someone look at this. You need drywall on the ceiling to hold the loose-fill insulation up over this soffit and between the framed walls on the ceiling. You also need fire-stopping from a horizontal to a vertical space, and every 10 lineal feet.
Page #4: http://www.codecheck.com/cc/images/CC5thEdSample.pdf There should be tin installed above and around the B-vent to stop any fire from reaching the attic space. The attic should be separate from any vertical space with drywall.
Be safe, Gary
Old 11-20-2009, 07:00 AM   #6
K.M.G's Avatar
Rewards Points: 113
Who are these people I call in to even look at the insulation???
There was tons more insulation,but it all fell on my head I can Guarantee 100% on that
So there's No proper way on building this...
Old 11-20-2009, 07:03 AM   #7
K.M.G's Avatar
Rewards Points: 113
Be safe, Gary
Are you serious...All i have had was Dry-wall for the last 20 years and it's been fine.
This house is in Ontario CDN
Old 11-20-2009, 07:05 AM   #8
of course there is a proper way to build it. Think of it as a small wall but upside down. Still get a top and bottom plate. Still have 2X4 16" on center. Still have insulation to separate the conditioned space from the un-conditioned space. One thing the Gbar mentioned is very important is to seal the air chase between a wall and a ceiling. When you create a soffit you create a new path that now must be sealed. Solid 2X blocking is one way or fireproof caulking (smaller areas only) You do not want an air flow since this will cause a rapid spread of any fire.
Old 11-20-2009, 07:35 AM   #9
Just because nothing bad that you know about now does not make doing something wrong FINE..... It is work like this that is really going to keep the housing market down. I do about 1.5 million each year just fixing all this fine work after it fails.
Old 11-20-2009, 07:48 AM   #10
Old School
Willie T's Avatar
Basically, 7 pieces of wood. The 3 reds can be the same length, and the 4 others (green & blue) can be identical. It won't go together QUITE like I've drawn it, but it will work either way..... except as I've drawn it, one red will be 3" shorter than the other two.
The PURPLE blocks are the fire blocking. You can see clearly how they stop a fire in the lower wall from flaming up into the cavity above the shower, then quickly on upwards to your daughter's bedroom... or to the attic area, then spreading all across the house. Fire blocking buys TIME! Time to get your loved ones out of the house, and time for the fire department to extinguish the blaze before it consumes your whole house. It is not only illegal not to install it, but also pretty foolish, considering the cost in lives and damage it can save.
Remember that the brakes you had on your first auto stopped the vehicle just fine.......... in about 75m. So why bother with Anti Lock Braking Systems, better pad material and better and safer tires used in today's cars? Why? Because they save lives by hauling that hurtling cage of metal down to a stop in sometimes 40m.
Whats the proper name for this-shower-1.jpg   Whats the proper name for this-shower-2.jpg   Whats the proper name for this-shower-3.jpg
Willie T
Old 11-20-2009, 10:08 AM   #11
K.M.G's Avatar
Rewards Points: 113
Since we are on this subject now
I found this insulation stuffed here...
Should I remove it and can anything get in if I do
When we had the Roof done we asked for 10 vents to be installed,we only had 3 on 1500 Sq Ft house.
The house was always super hot too untill the central air was installed about 4 years ago.
Old 11-20-2009, 01:17 PM   #12
remove and replace the insulation that has black spots on it (mold)
Old 11-21-2009, 12:22 AM   #13
Registered User
Attic venting: http://www.buildingscience.com/docum...on?full_view=1
Figure 1/100, not as in site: http://www.airvent.com/homeowner/pro...it-specs.shtml
Ice dams: http://bct.nrc.umass.edu/index.php/p...ting-ice-dams/
Your 1500 needs 5 sq. ft. of NFVA, IF you have a v.b. in attic/ceiling, ½ soffits and ½ ridge. 2.5’ x 144 = 360 sq. in. ridge at 18 sq.in.(or ?, depends on brand) per lin.ft. = 20’ of ridge or 8 ? of the 8x8 turtle backs. Depends on the size and NFVA as the site said.
Be safe, Gary
Old 11-22-2009, 10:05 AM   #14
K.M.G's Avatar
Rewards Points: 113
Thanks for the help everyone
This whole job has been taken out of my hands
So I don't even have to worry
I won't voluteer my time to try jobs anymore
But thanks for the advice
Proper way to install chimney pipe in metal building roof jonblack Building & Construction 15 01-31-2012 10:50 AM
proper material for service grounding rod? Jim S. Electrical 9 02-05-2009 09:25 PM
Proper way to install gutter flashing? Kasfidan Roofing/Siding 3 03-17-2008 12:57 AM
Help! What is Proper Way to Install Manufactured Stone? EricW Building & Construction 3 01-07-2007 03:56 PM
What is the proper ventilation needed? Ice Damns causing problems. alanisaacson Roofing/Siding 1 01-07-2005 01:38 PM
