Whats The BEST Window Flashing? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-07-2009, 02:35 PM   #1
Rewards Points: 562
whats the BEST window flashing?
I have been using the sticky tape butyl stuff 9" wide. Problem is even on clean perfect typar paper it comes loose very soon after install. Whats it lool like under siding after 10-30 years?? Is it as curled and unstuck as I see in a couple weeks uncovered??
I wonder of using the aluminum solid stock since anywhere you drive a nail you dimple it in and water is sure to follow. How close to a window do you nail vinyl siding??
Some guy posted a long detailed post on flashing the windows complete with alot of photos,,,any body know where to find it??MY search came up empty!!
What is best product and methods for flashing vinyl windows with nailing fin and using vinyl siding??
4just1don is offline   Reply With Quote
Old 06-07-2009, 05:30 PM   #2
Rewards Points: 5,336
The sticky stuff goes on the sheathing, not the house wrap. The house wrap goes on top of the sticky stuff. The cap flashing goes under the sticky stuff.
Ron
Old 06-07-2009, 05:35 PM   #3
Tom Struble's Avatar
Rewards Points: 2,002
i bet your talking about tinner the man knows his stuff
http://www.albertsroofing.com/
Tom Struble is offline   Reply With Quote
Old 06-07-2009, 08:47 PM   #4
Rewards Points: 156
I used Tite Seal by Cofair, got it from my local True Value hardware store. It stuck just fine, in fact got messy a couple times if it stuck to itself, forget it cut another peice, no way it was going to seperate from itself
creamaster is offline   Reply With Quote
Replacement Aluminium Window - Reusing existing sill flashing? GrantJohnson Building & Construction 4 02-10-2010 11:27 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Window Flashing compromised Rubu Building & Construction 4 10-09-2008 05:39 PM
Window Sill flashing? sandyman720 Building & Construction 6 08-06-2007 10:24 PM
window flashing RickT Carpentry 6 10-26-2006 08:29 PM
