What Is This White Tube In My Backyard? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-07-2011, 10:36 AM   #1
What is this white tube in my backyard?
It used to have a covering over it, but I ran it over on accident with the lawnmower and it broke off. What is it and do I need to cover it back up?
If so, what couls I use to cover it back up? It seems to be made of plastic or pvc pipe.
What is this white tube in my backyard?-p1060172.jpg   What is this white tube in my backyard?-p1060170.jpg   What is this white tube in my backyard?-p1060171.jpg
limitdiy is offline   Reply With Quote
Old 06-07-2011, 10:48 AM   #2
Not 100% sure but it could be the pressure/overflow tube for your drain in your house. So let say your toilet gets clogged, instead of blowing up your other ones or sink drains it will blow the cap off that pvc pipe in your backyard. My other guess is a drain for your backyard going from your backyard to the city drain on your street. Hope this helps.
Adamdy25 is offline   Reply With Quote
Old 06-07-2011, 10:54 AM   #3
Rewards Points: 6,652
It is a sewer clean out for your house. You need to dig down around and cut even to repair, then place a cap back on it.
The Following 2 Users Say Thank You to gregzoll For This Useful Post:
JKeefe (12-08-2014), ron45 (12-08-2014)
Old 06-07-2011, 12:35 PM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
It is either a clean out or a vent. If you can find what used to be on top you can get a clue as to which it was. If it was a vent then you need to put a vent cap back on it. If it was a clean out, then a female fitting with a threaded plug. Dig around it. Cut it off square and replace the missing parts. Extend it high enough to be above the ground, same as it was before. You need to do this before dirt, tennis balls, toys and debris get dropped into the line or tank and find their way to someplace that will cause you nightmares later on.
Old 06-08-2011, 05:33 AM   #5
It seems like overflow tube. You can expand the length to ground height. And cover it with round shape with a valve to use it.
Petric is offline   Reply With Quote
Old 06-08-2011, 05:42 AM   #6
Rewards Points: 1,536
If it is a vent then it needs to be above the ground surface so rain water does not go into it.
Old 06-08-2011, 08:30 AM   #7
Rewards Points: 152
Likely a cleanout. Should be capped as in picture below:
burnt03 is offline   Reply With Quote
Old 06-08-2011, 12:17 PM   #8
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 698
Do you have city sewer or a septic system?
WirelessG is offline   Reply With Quote
Old 06-22-2011, 03:57 PM   #9
Rewards Points: 14
WOuld like to know what these are aswell. I have two in my yard. In between the perimeter of my yard and neighbors, mine isnt broken.
I have city sewage.
Limeybstrd is offline   Reply With Quote
Old 06-22-2011, 06:03 PM   #10
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
Looks like hole 18 of a mini putt course.
Yeah probably a cleanout or vent, odd location to have it outside, but actually not a bad idea. You could maybe have someone flush the toilet while you put your ear to it. If it's connected to the drain system you should hear something.
Old 06-22-2011, 11:00 PM   #11
Limey,
If they have caps, then they're clean outs for your sewage. In order to be certain, use a 15" adjustable crescent to remove the cap and look inside. If it curves towards the city sewer hook-up, then it's a clean out.
Use the excellent pic Burnt03 provide above for reference.
VIPlumber is offline   Reply With Quote
Old 06-23-2011, 07:08 AM   #12
Rewards Points: 14
Originally Posted by VIPlumber View Post
Limey,
There is no lid or cover on mine. Doesnt look to have ever had one. I tried sniffing it last night but it emitted no smells
My sewage clean out pipes are similar to the ones posted above, they are located close to the house and are capped off.
Im wondering if mine is water well related?
Old 06-23-2011, 08:07 AM   #13
Gbm
Too small for well casing and too big for discharge. Wrong grass for putting green <grin>. Possibly air vent for bomb shelter?
From the type of grass it reminds me of living in Florida. Where I lived they allowed roof drains to be piped into the storm water systems as drainage was an issue and thin wall PVC was used. So if not a cleanout for sewer or septic then possibly a cleanout for that.
Gbm is offline   Reply With Quote
Old 06-23-2011, 02:16 PM   #14
If you want to spend some money on it, a sewer service can scope it out with a mini cam and find out where it goes.
Kenlguy is offline   Reply With Quote
Old 12-07-2014, 07:59 PM   #15
Rewards Points: 6
I have the same thing in my yard and I am not sure what it is for. I have a septic tank system. I have been wondering for some time as to where my leech field is but this may give me a clue. I thought it was in the back of my house. What is this white tube in my backyard?-20141206_093134.jpg
studders3 is offline   Reply With Quote
lowering backyard level & window to crawl space greenpointer Building & Construction 2 03-14-2011 07:40 AM
basic white paint mcl6302 Painting 6 10-11-2010 04:58 PM
turning white to antique white rustyedge Painting 6 10-01-2010 12:08 PM
black, white, white, black! bamaranch General DIY Discussions 5 07-04-2010 12:24 PM
Lutron Satin Snow compares to Cooper Satin white tomas21 Electrical 2 09-16-2008 03:21 PM
