What To Use To Shave Metal - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-09-2010, 03:41 PM   #1
Rewards Points: 154
What to use to shave metal
Hello,
I would like to shave a bolt hole to be a little bigger on the top. It's a oval so I would like to shave the top more so it can sit lower. I have a Dremmel but my attachments are too weak. The latch may be 2-3mm thick. Any suggestions?
llckll is offline   Reply With Quote
Old 08-09-2010, 03:58 PM   #2
Rewards Points: 24
Not sure that I follow the oval shaped hole for a screw to set in, but perhaps use a larger drill to make the chamfer deeper?
Old 08-09-2010, 04:06 PM   #3
Electrician
Proby's Avatar
A Dremel with a barrel shaped sanding wheel will probably work. Any big box store will have these.
When I need to do this in a pinch I drill another hole above it so that the holes intersect, then file down each side flat.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-09-2010, 09:07 PM   #4
Rewards Points: 154
Hi guys,
Here's a pic of what i'm talking about. Need to shave up more where the red boxes are.
I have a dremel, but the bits that I have don't seem to do anything to the metal.
Old 08-09-2010, 09:10 PM   #5
Electrician
Proby's Avatar
Originally Posted by llckll View Post
Hi guys,
So go get a bit that will file metal...
Old 08-09-2010, 09:13 PM   #6
Rewards Points: 154
Any suggestions?
Old 08-09-2010, 09:19 PM   #7
Electrician
Proby's Avatar
Any suggestions?
For 3 holes, you can pretty much get away with anything that fits the hole.
They make sanding drums that look like they'll fit right in there. Grinding stones as well.
Old 08-09-2010, 09:20 PM   #8
Rewards Points: 154
Thanks. I was looking at the www.dremel.com site. Not sure which one is strong enough to shave the metal a little higher.
Thanks.
Old 08-09-2010, 09:21 PM   #9
Rewards Points: 24
I would just clamp it up in a vise, maybe mark it with a pencil to avoid getting carried away, and have at it with a simple rat tail file. Yes, there might be faster methods, but it looks like maybe 10-15 minutes to me, including blocking it into the vise. But, if that is a hood latch, you may want to reconsider, due to possible liability issues, in the event of a failure; it obviously has adjustment already factored into its' design, so if it's still not working, you may have another issue in play. Just my simple, respectful 2 cents worth.
Old 08-09-2010, 09:22 PM   #10
Rewards Points: 5,336
Why not use a circular metal file?
Ron
Old 08-09-2010, 09:35 PM   #11
Electrician
Proby's Avatar
Ron
I figured he's save money by buying a $1.30 bit vs. a file.
Both will work.
Old 08-10-2010, 07:07 AM   #12
Household Handyman
Rewards Points: 1,408
I work on older cars quite a bit and this situation comes up often. I would mark the area to be enlarged with something like a "Sharpie" pen, your color choice, and do use a "rat tail file" to enlarge the slots as needed. This method will give you total control on how wide and how long to enlarge the slots. After getting the slots to the proper size you need, use a smaller, finer rat tail file to smooth out the edges and you will have a nice piece there. The Sharpie markings can be removed with fingernail polish remover. David
Old 08-10-2010, 02:46 PM   #13
Rewards Points: 562
they make a cone shape rotary file that fits in a regular drill chuck,,lots faster and better sized for that job than a dremel
4just1don is offline   Reply With Quote
Old 08-10-2010, 05:01 PM   #14
gmhammes's Avatar
I also agree with a metal file. It will be the quickest and most precise.
gmhammes is offline   Reply With Quote
Old 08-22-2010, 02:53 PM   #15
Metalman
what to use to shave metal
Know anybody in a machine shop? It would take about 5 minutes on a Bridgeport mill.
dave1123 is offline   Reply With Quote
Clearcoating a Stripped Vintage Ferrous Metal Medicine Cabinet? Lovegasoline Painting 15 08-31-2013 10:32 PM
Getting shocked by multiple metal items in room thms Electrical 14 06-24-2010 02:23 PM
condensation leak with metal roof on cathedral ceiling in Canada Serialrenovator Roofing/Siding 10 02-02-2010 01:18 AM
How to drill through metal in headers Docfxit General DIY Discussions 5 07-05-2009 11:31 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
