Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 12-18-2010, 09:44 AM   #1
What is a typical permitting process like?
I'm planning on adding some wiring to my garage and am curious to know what the "average" permit process is like.
After submitting my permit request (and assuming it is approved), do the inspectors have to look at the building before any work begins?
sheslostcontrol is offline   Reply With Quote
Old 12-18-2010, 11:12 AM   #2
Step 1. contact building inspection office
Step 2. Ask them what the process is
Each state has their own process and rules. Further, your local city, county may have different rules than the state does. Further, each jurisdiction has different enforcment rules
fireguy is offline   Reply With Quote
The Following User Says Thank You to fireguy For This Useful Post:
Thurman (12-18-2010)
Old 12-18-2010, 11:32 AM   #3
Household Handyman
Here's how easy it could be: I live in a County, not the City. In the County here if you have an existing "garage/shop/outbuilding" which is not attached to the "living area" of the home, you may darn well do most anything you want to it without obtaining permit(s). Totally different story within the City limits. If you have the same building sitting on property within the City limits you would have to obtain a permit to run "any new circuit" with electricity and be licensed, you can change out switches, outlets. But you cannot run any HVAC or new plumbing without a license. So see, different rules for each municipality.
Old 12-20-2010, 08:49 AM   #4
Coconut Pete's paella!
CoconutPete's Avatar
It all depends. Call the town and they can tell you. For my deck, I went to city hall and applied. They called me the next day and told me I could start digging. Then they came out and checked the depth of the holes for the footings and when it gets above 40 degrees in March sometime and I finish the stairs, they'll come back and give me final approval.
CoconutPete is offline   Reply With Quote
Old 12-21-2010, 04:06 PM   #5
Thurman, I'd challenge that, I've never heard of an area where the homeowner needs a license to do simple work like a new circuit on their own primary residence.
michaelcherr is offline   Reply With Quote
Old 12-21-2010, 04:42 PM   #6
Where I live (and I hear it's the same most places) homeowners are allowed to be their own contractor for building & electrical. We have to have our work inspected just like a licensed contractor to ensure the work is done correctly.
I got my permits this AM, so I'm all set.
Old 12-21-2010, 04:43 PM   #7
East Williston, NY for one. Munsey Park, Great Neck, Baxter Estates, Port Washington, Garden City, etc.....
There are hundreds, if not thousands of small villages and locales with this restriction.
Ron
Old 12-21-2010, 05:33 PM   #8
Experienced
Jackofall1's Avatar
Ron
Yep, East coast, where nobody knows nothin cept the contractors, and licenced installers, what a crock of poop!!!
Old 12-21-2010, 05:53 PM   #9
Pro Flooring Installer
rusty baker's Avatar
In the town where I live, the homeowner can do their own plumbing, electric, HVAC etc without a permit and no inspection. Structural work you need a permit, but they won't say anything unless someone complains. The county here is not zoned, so no building permits needed for anything. You can build your house from the ground up with no codes except for a septic tank.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 12-22-2010, 02:30 PM   #10
Rusty, Where do you live?
I think I might want to move there.
Old 12-22-2010, 02:52 PM   #11
Missouri, land of the free and home of the poor,
Old 12-22-2010, 03:12 PM   #12
Most cities in this area of Missouri (KC) will allow home owners to pull permits for electrical etc., but only if you reside in the property. If it is a rental or investment property, permits can only be pulled by a contractor that is licensed in that area.
KCMO Inspector is offline   Reply With Quote
Old 12-22-2010, 03:39 PM   #13
I rewired my house about 5 years ago. No permit or inspection needed if the homeowner does it. I lived and worked in the KC area for 20 years. On the Kansas side, I think you need an oxygen consumption permit to breathe.
Tags
electrical, inspection, permits
Anyone here built or in the process of building with SIPs? Badfish740 Building & Construction 1 09-30-2010 10:20 PM
Electrical Inspector Permitting problems zedman Electrical 27 11-27-2009 12:56 PM
new process or product for re staining or painting wood cabinets efox Painting 1 11-20-2009 04:35 PM
Typical joewho Off Topic 4 06-03-2007 01:33 PM
Home building process wilddngy General Discussion 19 04-06-2005 03:17 PM
