What Type Of Tubing Should I Use For The Drain Line Of The Softener? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-04-2013, 11:34 AM   #1
Rewards Points: 191
What type of tubing should I use for the drain line of the softener?
Any tips? Should I just get that clear plastic tubing? 1/2"? Larger?
Appreciate any info!
amateurplumber is offline   Reply With Quote
Old 04-04-2013, 07:01 PM   #2
Rewards Points: 13,300
Most come with a drain line, I've never seen one with a 1/2" fitting.
Most just use polyflo tubing.
Clear plastic will harden up.
Old 04-05-2013, 02:46 AM   #3
In My home the softener drain is routed into the water heater closet in the garage and dumps into the drain with pvc and a stand off..
adlermark321 is offline   Reply With Quote
Water Softener drain jpau00 Plumbing 6 02-18-2014 07:04 PM
Vent line has goes UP, down, UP - can I drain lowest point? calphalon Plumbing 22 09-20-2012 10:06 PM
Broken/cracked kitchen drain line under house joshua1978 Plumbing 4 09-14-2012 05:59 PM
Water softener drain nicko Plumbing 1 12-07-2010 10:44 AM
Old Type Bath Drain Tool Junkie Plumbing 4 09-26-2007 04:05 PM
