What Type Of Screw To Use With Drywall Anchor? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-27-2011, 05:05 PM   #1
What type of screw to use with drywall anchor?
What kind of screws should I use with those plastic drywall anchors? I have noticed that something I buy comes with anchors and screws, the screws usually have threads all the way up the entire shank; however, when I go to the hardware store, the wood screws all seem to have a portion near the top of the screw (near head) where there are no threads. So what kind of screws are those ones that come with things that you buy (like a curtain rod, for example). I also notice that the threads look slightly different, like a bit bigger than those on wood screws?
Thanks so much for any help you can give me!
djgrant is offline   Reply With Quote
Old 07-27-2011, 05:12 PM   #2
Rewards Points: 6,652
They are a pointed course thread machine head screws.
Old 07-27-2011, 05:15 PM   #3
Rewards Points: 5,336
They sell kits in stores that include the screws and anchors, along with the bit. Those screws have the threads all the way up the shank.
Sheetmetal screws will also have the threads all the way up.
Ron
B. Franklin 1759
Old 07-27-2011, 07:18 PM   #4
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
The screw "type" really doesnt matter in a conical plastic anchor, as long as the diameter is correct, wood or sheetmetal screws will work just fine, and the head style makes no differance at all. Don't worry if your screw isn't fully threaded, as long you have enough thread to engage about 70% of the anchor you should see little or no differance in holding power
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 07-27-2011, 08:19 PM   #5
Actually you want course threaded pan head screws, not fine thread. Also, drywall screws are not the proper type to use with these anchors.
Old 07-27-2011, 09:51 PM   #6
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Actually, if the anchors are being used in drywall it makes absolutely no differance if you use fine, course, or drywall screws if you load is light enough. The drywall will fail long before the screw will seperate from the anchor. In concrete you can use sheet metal OR wood screws as well with no change to the failure rates.
Your holding power here comes from expansive forces of the plastic angainst the base material ( drywall in this example). If your load is a static shear load you could darn near skip the screw altogether and use a nail driven into the anchor
And the head makes absolutely no differance. Pan head, flat head, oval head, truss head, bugle head, etc.. It has NOTHING to do with the anchor. Use whatever head makes sense for the fixing you are anchoring
Old 07-27-2011, 10:15 PM   #7
Rewards Points: 1,092
Just make sure nothing like a fuel line is being anchored with the plastic ones, as in boiler/utility rooms. They melt in a fire; use the metal ones.
Old 07-27-2011, 10:48 PM   #8
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
the "metal ones" are usually made of lead or Zamac, which has a melting point of around 400 degrees F or less
Drywall Screw Selection DaveTile Drywall & Plaster 1 03-31-2011 12:17 PM
Ensuite Bathroom Rebuild - what type of drywall? mforeman1 Drywall & Plaster 2 03-25-2011 08:36 PM
What type of drywall for garage BlueBSH Drywall & Plaster 13 04-06-2010 12:54 AM
What type of drywall is this? avro1 Drywall & Plaster 11 03-03-2010 10:09 PM
Type of drywall for wine cellar... Goliath Building & Construction 3 02-03-2006 12:11 AM
