Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 05-07-2008, 03:59 PM   #1
What Type Of Saw Will Cut Steel??
I need a saw that will cut steel bars off my basement windows. The bars were cemented into the house (its an old house)...so the best way to take the bars off is by sawing them.
What type of saw do I need????
P.S. The steel bars are approximately 3 centimeters thick.
nflnetwork is offline   Reply With Quote
Old 05-07-2008, 04:01 PM   #2
Underground Techie
sevver's Avatar
Concrete saw with an abrasive blade.
sevver is offline   Reply With Quote
Old 05-07-2008, 04:04 PM   #3
I have gas!
Clutchcargo's Avatar
If you're only cutting the bars a recipricating saw.
Sawzall is my favorite.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 05-07-2008, 04:11 PM   #4
Moderator
Termite's Avatar
A reciprocating saw will work just fine. Just get a couple metal-cutting blades. You can get a recip saw for less than $100 these days, or rent one.
Old 05-07-2008, 04:14 PM   #5
Underground Techie
sevver's Avatar
I prefer speed myself, a reciprocating saw will work, even a hacksaw will work. But to get it over with, concrete saw, less than two minutes, done.
Old 05-07-2008, 07:12 PM   #6
Advice worth 2 cents!
I love using Zip-cut's......Dangerous and efficient!
They fit on a small buffer that you can buy for like 30 bucks.
-pete
---pete
HandyPete is offline   Reply With Quote
Old 05-07-2008, 09:28 PM   #7
General Contractor
joasis's Avatar
A recip with a good bi-metal blade will cut a one inch bar in less then a minute.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Old 05-07-2008, 09:38 PM   #8
Tired, Cold, and Damp
slickshift's Avatar
Recip saw (often called a "Sawzall", which is a brand name), metal blade (blade for cutting metal)
The blades will even be labeled for different types of metal and speed vs. cleanliness of cut
slickshift is offline   Reply With Quote
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
How to butt wood stud wall to steel stud wall? Yorkergizer Building & Construction 3 12-01-2007 01:28 AM
A steel building that doesn't look like a steel building? MMW Building & Construction 1 06-11-2007 05:24 PM
steel under shingles orlockorlok Roofing 8 05-30-2007 09:44 PM
Type L Or M Copper Pipe bobo Plumbing 1 11-20-2005 08:53 PM
