Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 08-12-2011, 11:31 AM   #16
What type of Caulk to Use
I would look at this situation the same as painting an object. What type caulk has given problems, and was it applied properly?
A lot of contractors will use the cheapest product that will do the job. If this is the case, removal is necessary!
I would rather spend more money and do the job right, remove and reapply QUALITY caulk If a window unit is sound, with no visible problems, let it go. If silicone (unpaintable) caulk was used--I don't believe even new silicone would adhere to it
Even the best paint or caulk is no good without the proper, clean, sound base
Giles is offline   Reply With Quote
Old 08-15-2011, 01:59 AM   #17
In my opinion-if you want to hire this contractor to do the work, and he is a good painting contractor- Then he should be the one picking out the caulking.
Since he is a professional, he should/will know what caulk to use, a good painting contractor will know his caulking, that is one reason you hire him in the first place- for his knowledge.
What you should be looking for is not trying to figure out kind of caulking to use.-He is the one who should be explaining to you what process/product will be used for the most successfull results, and why.
You should make sure you have a warranty on the caulking work, to make sure he stands behind the work and you get good value for your money.
He should be telling you what caulking will be used, should be more than happy to tell you why, and be more than happy to give you a warranty in writing on it.
chrisBC is offline   Reply With Quote
Old 08-15-2011, 04:22 AM   #18
Ricky008's Avatar
Originally Posted by Einhorn View Post
Our condominium was built 9 years ago. Most of the caulking is still looking good and filling the gaps, thus we don't feel that a complete removal of old caulking and re-caulking is required. (A total of 150 windows, doors, dryer and bathroom air outlets, etc..)
We've found a contractor we'd like to use who offers us three choices:
1 Removal of old caulk, clean, reapply new caulk (very expensive)
2 Simply patch areas where caulk has a gap between frame and brick.
3 Apply new caulk the entire length of the old caulk, just applying more of it, to form a wider seal.
We'd like to go with option 3 because its the same cost as option 2 (except for more caulk). Again, we don't feel that complete removal of old caulk should be required on a 9 year old building.
The contractor told me that good caulk is expensive, but will last much longer. So what I'm looking for is recommendations on what is a "good caulk".
The contractor specializes in painting. He does caulking also but he is not a dedicated caulking contractor.
He mentioned that there's Oil and Water based caulks. I asked if he could tell us what was originally applied but he says that with 9 year old caulk, he can't really tell.
For paints, the thinking was, historically, oil based paints will stand up longer when used for exterior purposes. Is this the same for Caulking?
Essentially, we have a good contractor, but I want recommendations on what to use for caulking material. I know that there's a lot more than Oil and Water based, there's silicone, and lots of other options, so any recommendations would be appreciated.
Caulk comes in many types (latex, silicone, and urethane) and choosing the right caulk for the job is important. Using the right caulk will both seal and protect, whether it’s gaps around a window or a tub — and you won't have to repeat the job any time soon.
  • Silicone is a great overall caulk and essential if you’re working with nonporous areas, such as bathtubs, showers, sinks, and so on.
  • Tub and tile caulk is an acrylic sealant that includes a mildew-resistant ingredient that makes it ideal in wet areas.
  • Urethane is also a good caulk for most other surfaces and has the added bonus of being paintable.
  • Elastomeric latex caulks are great for exterior cracks because it prevents the seal from expanding and contracting.
Ricky008 is offline   Reply With Quote
Old 08-17-2011, 11:01 PM   #19
Moderator
More info on backer rod, I think Man.6 mentioned them also. Page 30: http://books.google.com/books?id=fDs...age&q=&f=false
http://www.crossroadsci.com/LinkClic...t.pdf&tabid=80
Page 35: http://books.google.com/books?id=XHA...0break&f=false
An hour-glass shape: http://docs.google.com/viewer?a=v&q=...X1IjstvXQPNoxA
http://www.coastalcontractor.net/article/117.html
They may repeat, sorry....
Gary
Clothes taking longer to dry?
Old 08-21-2011, 03:50 PM   #20
gravity always wins
Here ia a little guide that might be easier.
http://www.masterwall.com/files/mw14...lantdesign.pdf
For what it's worth, practically ALL caulks and sealants are ELASTOMERIC. That simply means that when cured, they have elastic properties that will allow them to flex to absorb movement, whether it's dynamic motion, expansion/contraction or swelling/shrinking.
Recaulking at previously silicone-caulked shower door frame hffeagan Kitchen & Bath Remodeling 33 01-03-2013 12:58 AM
Circuit breaker Type Q vs QP orange Electrical 6 12-15-2010 04:35 PM
How to Clean Up Caulk Mess on Driveway Left By Construction Crew ToolbeltGal Building & Construction 6 09-25-2010 05:36 PM
Can anyone recommend a good caulk? lhhandyman Plumbing 7 06-01-2009 06:22 AM
Type WL Copper Pipe bathroom slave Plumbing 1 01-26-2009 01:30 AM
