What Tool Do I Need?? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-06-2011, 10:24 PM   #1
What tool do I need??
I am trying to remove the brass mounting nut from the underside of a widespread faucet in the bathroom. There is not much room under there and I was unable to take the nut off with a regular wrench. I tried a basin wrench, but again there wasn't much room to get the basin wrench in around the nut. I also bought the RIDGID faucet installer tool but the valve is too big for the shaft of the tool so I can't even get the tool up to the nut. The nut may be around 1.25" and the tool is 1 and 1/16".
The plumbing is probably about 20 years old(original). What tool do I need?! I am not sure how they even installed the thing! The only way I can think of is that they installed them on the sink and then laid down the sink. I do not want to remove the sink! Not sure if this is a small project or what. Is there some type of slotted socket wrench out there? I see shower valves that are 1 to 1.5" that would work for the spout nut, but the hot and cold nuts have valves out to the side, so there needs to be a slot. Should I buy a shower valve and then cut a slot?(Don't have any metal cutting tools though)
Thanks!
wholeinone04 is offline   Reply With Quote
Old 11-06-2011, 11:47 PM   #2
Was able to get the faucet off but not sure what to do about the hot and cold nuts.
What tool do I need??-photo-5-.jpg   What tool do I need??-photo-4-.jpg   What tool do I need??-photo-3-.jpg
Old 11-07-2011, 06:29 AM   #3
There are inexpensive basin wrenches available, but you only need something to hold the bottom nuts, or the valve body. The top chrome nuts are what holds the valve bodies in place. Water pump slip joint or similar pliers usually works there. They unscrew and the body comes out the bottom.
Old 11-07-2011, 07:54 AM   #4
joed's Avatar
Rewards Points: 12,406
It's called a basin wrench.
Clamping tool or Oscilating tool for a DIY'r-you can only pick one which would it be? whataboutj Tools 12 11-29-2010 07:12 AM
Review: Harbor Freight Oscillating Tool Tedstor Tools 0 07-13-2010 02:24 AM
Need Help with re-design ttwiss Remodeling 21 05-08-2010 10:27 PM
Fein's Multimaster Tool...don't let the price scare you! CrossWorks Tools 13 04-18-2009 06:39 PM
Drywall Inside Corner Tool? helpless handyman Drywall & Plaster 24 02-19-2009 06:02 PM
