What Steps Do You Take To Prepare Your Home For Winter? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-21-2015, 12:40 PM   #1
Administrator
Cricket's Avatar
Rewards Points: 1,898
What steps do you take to prepare your home for winter?
"Even though it may still be a few months before we have to worry about ice and snow, now is the time to start getting your home ready for the chilly months ahead. Sure, it seems early, but starting early will ensure that you donít leave out important steps that could save you money on your heating costs this winter." Itís Time to Start Getting Your Home Ready for Winter
Join DIY on Facebook today!
facebook.com/DIYChatroom
Cricket is offline   Reply With Quote
Old 09-21-2015, 12:50 PM   #2
Wildbill7145's Avatar
Rewards Points: 88
Stack 10 cords of firewood.
Wildbill7145 is offline   Reply With Quote
The Following 2 Users Say Thank You to Wildbill7145 For This Useful Post:
craig11152 (09-21-2015), Cricket (09-21-2015)
Old 09-21-2015, 02:10 PM   #3
But firewood, get my oil contract , have my oil burners cleans and checked, make sure the snowblower is functional, clean up the leaves and clean the gutters
jimn01 is offline   Reply With Quote
Old 09-21-2015, 04:06 PM   #4
Rewards Points: 7,736
Close windows, turn on the heat.
Old 09-21-2015, 04:18 PM   #5
joed's Avatar
Rewards Points: 8,126
Except for the regular yard work of leaves and dead flowers turn on the furnace.
Old 09-21-2015, 09:22 PM   #6
Rewards Points: 1,179
When these nights start to turn chilly, bugs start looking for a warm place to spend the winter. Adjust your adjustable door thresholds so that you can just pull out strips of paper with a bit of effort. On storm doors check the adjustable sweep to make sure it runs into the threshold.
Spread perimeter insecticide around your foundation on the outside.
ChuckF. is offline   Reply With Quote
Old 09-21-2015, 09:27 PM   #7
Rewards Points: 3,037
If it is not a bad month I manage to unscrew the hoses from the bibs and switch the thermostat from cool to heat. The thermostat is usually after freezing my *** off for one night.
Colbyt
I often use the Thanks button as a ditto button or +1 button.
Colbyt is online now   Reply With Quote
Old 09-22-2015, 08:23 PM   #8
Rewards Points: 254
Switch the thermostat from a/c to heat
cjm94 is online now   Reply With Quote
Old 09-22-2015, 09:07 PM   #9
Property Mgt/Maint
Rewards Points: 3,048
Fire wood, clean the chimney, check windows, bring in hoses, rake some leaves, clean gutters, put plow on tractor, remount snow tread tires,
rotate summer to winter clothes.
please use your imagination to fill in any missing or miss-spelled words!
Yodaman is online now   Reply With Quote
Old 09-23-2015, 12:32 PM   #10
Rewards Points: 365
Switch the heat pump remote from A/C to heat.
Shut off the water to the barn, drain the pipes, and pour RV antifreeze in the traps.
Switch from lighter beer to darker beer.
MushCreek is online now   Reply With Quote
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 08:42 PM
Adding exterior drain with concrete steps in way steveel Building & Construction 5 09-10-2010 05:23 PM
steps to building a home? am i correct? katerwal Building & Construction 2 03-12-2005 12:14 PM
A facelift for your home Grumpy Remodeling 0 07-07-2004 08:43 PM
