What Are Some Basic Tools I Should Have? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-27-2016, 02:53 PM   #1
Rewards Points: 12
What are some basic tools i should have?
Hi,
I need to do a few repairs on a building. Over the years ive never really had much of a problem fixing things, but i always used a friends set of tools. Now i've moved across the country i have to get my own set. What are some basic things i should get? is there like any multi set worth getting from amazon (Im based in uk, but amazon uk has most things the .com has)
bigyellowones is offline   Reply With Quote
Old 01-27-2016, 03:29 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,194
Depends entirely on the repairs.
There are some decent all-in-one type sets at the big box stores that will probably cover a bunch of your needs.
Old 01-27-2016, 04:09 PM   #3
http://www.harborfreight.com/
ron45 is offline   Reply With Quote
Old 01-27-2016, 04:51 PM   #4
WhatRnsdownhill's Avatar
Rewards Points: 2,220
how much do you want to spend?
WhatRnsdownhill is offline   Reply With Quote
Old 01-27-2016, 06:02 PM   #5
Rewards Points: 13,960
Good luck with this question, we still have no idea where you are or what your looking to do so this post is going to just go on and on.
With that little info, just buy what you need as you need it.
Old 01-27-2016, 06:11 PM   #6
Rewards Points: 582
hammer , speed square, 2' framing square, screw drivers, flat and phillips, saw, level 2'and 4', channell locks, pliers, small pipe wrench, tubing cutters, torch, power saw, miter saw, cordless drill, power drill, saw horses, router, table top saw, electrical tools, drywall tools, concrete tools, hvac tools,...this may get you started..
Old 01-27-2016, 06:11 PM   #7
ZTMAN's Avatar
Rewards Points: 472
Simple, start off with buying all the tools you used to borrow the most. Also have repair items on hand. Ie, supply lines for toilets and sinks, extra toilet valve kit, couple of shut off valves and plumbing fittings and extra hose and coupler for fridge ice maker etc, etc... When your workshop looks like home depot, you are about done.
ZTMAN is offline   Reply With Quote
The Following 2 Users Say Thank You to ZTMAN For This Useful Post:
dd57chevy (01-28-2016), joecaption (01-27-2016)
Old 01-27-2016, 06:19 PM   #8
Rewards Points: 82
Originally Posted by bigyellowones View Post
Hi,
At least you should have the following basic tools:
1. Flat and Philipp Screwdriver
2. Wrenches
3. Hacksaw
4. Hammer
5. Sandpaper
6. Grinder
7. Drill
8. Torque Wrences
9. Impact Sockets
These basic tools can be found the in you nearest hardware stores or online shop like amazon or ebay.
cmorales is offline   Reply With Quote
Old 01-27-2016, 06:23 PM   #9
Property Mgt/Maint
Rewards Points: 1,480
Hi,
This should be easy. Just think back, make a list of every tool you have borrowed over the years and go shopping.
Yodaman is offline   Reply With Quote
The Following User Says Thank You to Yodaman For This Useful Post:
Old 01-27-2016, 06:47 PM   #10
kwikfishron's Avatar
Rewards Points: 760
In my view there's no need to buy a bunch of tools based on projects that may or may not happen in the future. As projects come up buy what you need to tackle them as you need too.
That said a tape measure, a couple screwdrivers, a roll of duck tape and a small hammer should always be in the junk drawer.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Old 01-27-2016, 06:50 PM   #11
Rewards Points: 1,010
You really need only two things:
spaceman spif is offline   Reply With Quote
The Following 6 Users Say Thank You to spaceman spif For This Useful Post:
craig11152 (02-03-2016), Cullen (01-29-2016), dd57chevy (01-28-2016), die4irish (01-27-2016), lenaitch (01-28-2016), ZZZZZ (01-27-2016)
Old 01-28-2016, 08:26 PM   #12
Usually Confused
lenaitch's Avatar
Rewards Points: 1,948
You said you've "moved across the country" and based in the UK. Obviously, any screwdrivers you get should match whatever heads they use over there. Also, if you decide to get socket wrenches, you many well need both metric and imperial sizes.
lenaitch is offline   Reply With Quote
Old 02-02-2016, 05:33 PM   #13
Rewards Points: 352
My idea of a very basic tool kit for home/apartment/condo.
Claw hammer
Small assortment of various size and types nails
punch/nail set
4-6 screwdrivers (common types/sizes)
Ice pick
2-3 adjustable wrenches
Pliers
Large adjustable pliers (Channel locks)
Diagonals (wire cutter)
Small level
Utility/razor knife
Tape (electrical, masking, packing, duck)
Tube of lithium grease
3M oil (small can)
Super glue
Wood glue
RegeSullivan is offline   Reply With Quote
Old 02-03-2016, 03:17 AM   #14
It mostly depends on how much is your budget. You get some great quality tool set online in real cheap price.
smithwatson7 is offline   Reply With Quote
Old 02-03-2016, 06:08 AM   #15
craig11152's Avatar
Rewards Points: 298
well played...you made my day and its just past 7AM
Don't look at me. I didn't vote for either one of them.
craig11152 is offline   Reply With Quote
Basic HVAC tools -what do I need to buy PF4DIY HVAC 42 12-03-2014 03:28 PM
Tools required for the job? joshdonlan Carpentry 13 01-29-2014 07:30 PM
Storing garden tools with woodworking tools? CJIII General DIY Discussions 11 05-26-2013 10:08 PM
A variety of used carpentry tools Toolmannewbie Carpentry 5 04-29-2013 07:25 PM
