What Size And Type Of Nails To Use - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-15-2009, 07:27 AM   #1
What size and type of nails to use
I am building a 8' X 36' pulpit platform for a church and I am using 2 x 8's. What size and type of nails should I use for this? Also what size and type of plywood should I use and what size and type of nails should I use for this?
Should I use wood glue also, what is the reason for glue? I don't want the pulpit to squeak when someone walks accross it. That would be so embarassing for me. I would appreciate any help you can give me. Thanks!!
keviadams is offline   Reply With Quote
Old 09-15-2009, 08:27 AM   #2
Old School
Willie T's Avatar
Should I use wood glue also, what is the reason for glue? I don't want the pulpit to squeak when someone walks across it. That would be so embarassing for me. I would appreciate any help you can give me. Thanks!!
Truthfully, I would go ahead and use 3" "roberts head" screws for the few extra bucks it will cost. And "yes" run a substantial bead of construction adhesive (liquid nails in a big caulking tube) on top of all your joists.
Use 3/4" tongue and groove plywood. The T&G will eliminate any chance of misaligned sheet edges. I would even use screws on the plywood... no shorter than 1-1/2".
Also spring for sound-deadening insulation underneath. You do NOT want the stage "booming" when someone walks across it. And if yours is a contemporary church with musicians, their instruments will reverberate inside a hollow stage.
Willie T
Old 09-28-2009, 12:25 PM   #3
Thanks so much! This was a great help.
Please confirm wire size and type for amperage. wantsomegetsome Electrical 14 05-07-2009 05:49 AM
What type size mesh to keep out rats/mice? darsunt Pest Control 3 11-21-2008 10:35 AM
Nail size and Type ????? mjkpainting Carpentry 7 11-21-2008 02:06 AM
What nails to use? 2x4 framing, osb sheathing jw15842 Carpentry 6 09-08-2008 10:31 PM
What type / size screws for subloor project... scheenstra Building & Construction 1 05-17-2008 08:22 PM
