#1 |
What size sheet rock for garage ceiling?
I live in Colorado and run a screen printing business. This is the first winter that I've had to run it out of my garage. The problem is my inks, emulsions, etc. are freezing. I need to insulate the garage. I've started to insulate. Do you have a recommendation on sheet rock size for my walls and ceiling? I am not planning on finishing it out because its a garage and doesn't need to look pretty. Any other recommendations? Thanks, Bil
#2 |
Average Joe/ex-Navy IC3
5/8" Wallboard.
#3 |
What size is the garage? Idealy, you should get the size that will minimize the number of seams. You could buy 1/2" if the budget is tight, but 5/8" in a garage would be better. What kind of heat do you have in the garage?
#4 |
Lic. Builder/GC/Remodeler
Basically: 5/8" Fire-rated is required in a garage on any walls connected to your home. Free standing garage = 1/2" is all you need.
12'-0" sheets are the norm for installation, however, if you are going to install it yourself, I would suggest getting 8'-0" sheets as they will be much easier to handle and much easier to manuever.
- Build Well - |
#5 |
How far apart are the trusses. 24 inch spacing or 16 inch spacing on the trusses makes a big difference on what thickness drywall to use.
#6 |
You can actually run spanners across the joists if they are 24" apart to help secure. But 5/8" is the required in an attached garage. Watch some of the Holmes on Homes episodes and Mike Holmes talkes about "Proper Code", and of course Minimum Code Requirements.
#7 | |
What size sheet rock for garage ceiling?Quote:
(Personally, I do find the show interesting at times, .....but Holmes self-promotes and gets too "whiney"....Just explain the problem, express the disgust "ONCE".... and what the course of corrective action will be and why...with NO MORE additional "moping", "complaining" or "whining"....UGH!!)
- Build Well - Last edited by AtlanticWBConst.; 01-19-2008 at 01:23 PM. |
#8 |
Minimum Code Requirements is 1/2", but you might as well go with 5/8" and do it right the first time.
#9 | |
That doesn't make any sense?
- Build Well - Last edited by AtlanticWBConst.; 01-19-2008 at 07:20 PM. |
#10 |
What size sheet rock for garage ceiling? |
#11 |
5/8" will have less sag on the ceiling
#12 |
1/2" doesn't sag at all when installed 16" OC.
If there is framing that is beyond 16" OC, the correct solution (in the building industry) is to install strapping 16" OC...Using 1/8" more gypsum between two sheets of paper is not the solution.
- Build Well - Last edited by AtlanticWBConst.; 01-19-2008 at 10:04 PM. |
#13 |
Well, I've started the process and I am using 1/2" drywall because: 1) cheaper 2) lighter in weight (doing this by myself). The contractor at Home Depot told me that only the walls adjacent to the house need to be 5/8" fire rated dry wall, so it seemed overkill to outifit the entire garage. I've got trusses on the ceiling, is there any chance hanging 1/2" drywall on the ceiling will be too heavy or are 2 X 4 trusses made to carry a heavy load? Is there a lighter weight alternative that's cost effective? The garage is approximately 20' X 30'. Thanks for all your input.
| Display Modes | |
| Paint peeling off Bathroom Ceiling!!! | armen30 | Painting | 17 | 12-08-2011 09:26 AM |
| Height of a ceiling fan with a trey ceiling? | Bacardi 151 | Electrical | 7 | 09-08-2010 11:55 AM |
| Ceiling condensation | icemand | Building & Construction | 1 | 12-15-2009 06:16 AM |
| ceiling fan support | triplnikl | Carpentry | 5 | 03-06-2009 04:47 PM |
| ceiling joist size - 2x4 or 2x6 needed? | bigdaddy352 | Building & Construction | 9 | 08-21-2007 01:02 AM |
