-   -   What size sheet rock for garage ceiling? (http://www.diychatroom.com/f2/what-size-sheet-rock-garage-ceiling-15809/)
Billy Boy 01-18-2008 10:30 PM
I live in Colorado and run a screen printing business. This is the first winter that I've had to run it out of my garage. The problem is my inks, emulsions, etc. are freezing. I need to insulate the garage. I've started to insulate. Do you have a recommendation on sheet rock size for my walls and ceiling? I am not planning on finishing it out because its a garage and doesn't need to look pretty. Any other recommendations? Thanks, Bil
gregzoll 01-18-2008 10:43 PM
5/8" Wallboard.
jerryh3 01-19-2008 06:55 AM
What size is the garage? Idealy, you should get the size that will minimize the number of seams. You could buy 1/2" if the budget is tight, but 5/8" in a garage would be better. What kind of heat do you have in the garage?
AtlanticWBConst. 01-19-2008 08:39 AM
Basically: 5/8" Fire-rated is required in a garage on any walls connected to your home. Free standing garage = 1/2" is all you need.
12'-0" sheets are the norm for installation, however, if you are going to install it yourself, I would suggest getting 8'-0" sheets as they will be much easier to handle and much easier to manuever.
joed 01-19-2008 09:25 AM
How far apart are the trusses. 24 inch spacing or 16 inch spacing on the trusses makes a big difference on what thickness drywall to use.
gregzoll 01-19-2008 10:08 AM
You can actually run spanners across the joists if they are 24" apart to help secure. But 5/8" is the required in an attached garage. Watch some of the Holmes on Homes episodes and Mike Holmes talkes about "Proper Code", and of course Minimum Code Requirements.
AtlanticWBConst. 01-19-2008 12:14 PM
Originally Posted by gregzoll (Post 89889)
... But 5/8" is the required in an attached garage. Watch some of the Holmes on Homes episodes and Mike Holmes talkes about "Proper Code", and of course Minimum Code Requirements.
It's only required (per fire-code ratings) on attached walls and ceilings (walls or ceilings directly connected to the house - all other walls can have 1/2" standard GWB).
(Personally, I do find the show interesting at times, .....but Holmes self-promotes and gets too "whiney"....Just explain the problem, express the disgust "ONCE".... and what the course of corrective action will be and why...with NO MORE additional "moping", "complaining" or "whining"....UGH!!)
gregzoll 01-19-2008 02:34 PM
Minimum Code Requirements is 1/2", but you might as well go with 5/8" and do it right the first time.
AtlanticWBConst. 01-19-2008 06:18 PM
Umm, why would using 5/8" sheetrock be right over using 1/2", when it is not required??:huh: That doesn't make any sense?
jerryh3 01-19-2008 06:59 PM
Because he is a Mike Holme's fan.
comp 01-19-2008 08:51 PM
5/8" will have less sag on the ceiling
AtlanticWBConst. 01-19-2008 08:59 PM
1/2" doesn't sag at all when installed 16" OC.
If there is framing that is beyond 16" OC, the correct solution (in the building industry) is to install strapping 16" OC...Using 1/8" more gypsum between two sheets of paper is not the solution.
Billy Boy 01-24-2008 12:36 PM
Well, I've started the process and I am using 1/2" drywall because: 1) cheaper 2) lighter in weight (doing this by myself). The contractor at Home Depot told me that only the walls adjacent to the house need to be 5/8" fire rated dry wall, so it seemed overkill to outifit the entire garage. I've got trusses on the ceiling, is there any chance hanging 1/2" drywall on the ceiling will be too heavy or are 2 X 4 trusses made to carry a heavy load? Is there a lighter weight alternative that's cost effective? The garage is approximately 20' X 30'. Thanks for all your input. :thumbup:
