What Size Drive Through Gate? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-27-2008, 10:28 AM   #1
Rewards Points: 274
what size drive through gate?
I am planning on building a fence with a 12' drive through gate. Later on i will have a pond dug/built. Do you think the 12' gate will be big enough to allow trucks w/ heavy equipment through?
ugabulldog is offline   Reply With Quote
Old 07-28-2008, 07:20 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,648
Ayuh,...
Most all Dumptrucks are 8' wide,+ Most heavy equipment is Under 12' wide....
You should be Fine...
Bondo is online now   Reply With Quote
Old 07-28-2008, 10:57 PM   #3
Rewards Points: 2,906
If you're going to make a gate 12 feet wide, why not just measure the width of one lane of your local highways and make it that width.
Then, you'd even be able to fit the "wideload" trucks through if necessary.
Nestor_Kelebay is offline   Reply With Quote
Old 07-29-2008, 09:47 AM   #4
47_47's Avatar
Rewards Points: 62
I also think that 12-ft. will be fine, if the gate is on a relatively straight run and not on a curve or turn.
47_47 is offline   Reply With Quote
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-25-2011 11:29 PM
Gate for wooden privacy fence RookVega Landscaping & Lawn Care 2 11-09-2008 09:56 AM
What type / size screws for subloor project... scheenstra Building & Construction 1 05-17-2008 08:22 PM
sagging gate issue Thanat0s24 Building & Construction 2 04-17-2008 01:19 PM
Wire size and Breaker size for remodel ?? Skydmark1 Electrical 12 12-15-2007 05:00 PM
