What Should I Use To Mark Walls? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-13-2013, 06:17 PM   #1
Rewards Points: 150
What should I use to mark walls?
Im about to do some closet shelving, what should I use to mark the walls? I just painted these walls not too long ago and the thought of "marking" them doesnt sit well. Is there a special pencil or something designed to mark walls that will come off easy?
Arsinek is offline   Reply With Quote
Old 01-13-2013, 06:24 PM   #2
Rewards Points: 13,968
What type shelving?
Old 01-13-2013, 06:55 PM   #3
Rewards Points: 150
Originally Posted by joecaption View Post
What type shelving?
Closetmaid wire shelving. Getting it at Lowes.
Old 01-13-2013, 07:29 PM   #4
Rewards Points: 2,240
A carpenters pencil/pencil -
gently!
You can wipe it off.
Don't "break" the surface of the paint.
"RF"
rossfingal is offline   Reply With Quote
Old 01-13-2013, 07:31 PM   #5
" Euro " electrician
frenchelectrican's Avatar
use the " china " pencil that can be washable when you get done marking it.
Or second option is use the painter tape ( NOT the duck <duct> tape ) and mark it on there when ya done just peel it off.
Merci,
Marc
Old 01-13-2013, 07:36 PM   #6
Rewards Points: 150
Merci,
Marc
Never head of a China pencil. What is it?
Old 01-14-2013, 06:04 AM   #7
Mark vertical and horizontal lines with a LASER level.
oberkc is offline   Reply With Quote
Old 01-14-2013, 06:45 AM   #8
Rewards Points: 3,130
It is more commonly called a china marker. Basically a pencil that's made with hardened wax instead of graphite. You can buy them anywhere office supplies are sold (even Wal-Mart has them).
Old 01-14-2013, 07:17 AM   #9
Rewards Points: 1,476
I just use a regular pencil and write lightly. Then use a new pencil eraser to get it off.
Also, are you using once of those fancy closet kits with a bunch of half shelves? I bought one and then realized it would take hours of work and actually yield less usable space. I ended up just buying a long shelf so my son's closet has two long levels. Much easier and better use of space.
mikegp is offline   Reply With Quote
Old 01-14-2013, 07:51 AM   #10
the Musigician
DangerMouse's Avatar
IF, you're just trying to line up where the studs are to attach the shelves to a strong backing, you could just use rare-earth (hard-drive) magnets to locate the studs (screws), like I do/did. It works just fine and leaves no mark.
DM
Old 01-14-2013, 08:03 AM   #11
If you haven't purchased it yet, you may want to consider Rubbermaid Configurations instead.
I have installed both Closetmaid and Rubbermaid and the latter is much easier to install and I find in general just a better product.
Not sure why someone would suggest you have less use with those then just a regular system as I found the versatility offers a huge amount of storage space.
Even more than a custom closet with cubby type box shelves, even with adjustable height shelving
creeper is offline   Reply With Quote
Old 01-14-2013, 10:28 AM   #12
gently!
"RF"
What's with carpenter pencils not sharpening well, or the tips break off easily?
Adrenalinejunky is offline   Reply With Quote
Old 01-14-2013, 06:52 PM   #13
Rewards Points: 150
DM
I actually have something similar. Not sure theyre as strong as what youre using.
This is what I have...
http://www.magicstudfinder.com/index.html
Works pretty well. But sometimes Ill find a stud and these magnets will only find like one spot to stick to, which theoretically would mean there are no nails in it. I also use a zircon stud finder with these magnets.
Old 01-15-2013, 05:31 AM   #14
i generally use a standard carpenters pencil, never had any problems!
Click Plastics is offline   Reply With Quote
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
How bad are unencapsulated knee walls? deerhunter Building & Construction 0 11-02-2010 09:41 PM
Basement Walls - Which Paint?Drylok? HandyFrank Building & Construction 3 10-17-2010 12:07 PM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 05:59 PM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 08:17 AM
