-   -   What should I use to mark walls? (http://www.diychatroom.com/f2/what-should-i-use-mark-walls-169040/)
Arsinek 01-13-2013 07:17 PM
Im about to do some closet shelving, what should I use to mark the walls? I just painted these walls not too long ago and the thought of "marking" them doesnt sit well. Is there a special pencil or something designed to mark walls that will come off easy?
joecaption 01-13-2013 07:24 PM
What type shelving?
Arsinek 01-13-2013 07:55 PM
Originally Posted by joecaption (Post 1092759)
What type shelving?
Closetmaid wire shelving. Getting it at Lowes.
rossfingal 01-13-2013 08:29 PM
A carpenters pencil/pencil -
gently!
You can wipe it off.
Don't "break" the surface of the paint.
"RF"
frenchelectrican 01-13-2013 08:31 PM
use the " china " pencil that can be washable when you get done marking it.
Or second option is use the painter tape ( NOT the duck <duct> tape ) and mark it on there when ya done just peel it off.
Merci,
Marc
Arsinek 01-13-2013 08:36 PM
Merci,
Marc
Never head of a China pencil. What is it?
oberkc 01-14-2013 07:04 AM
Mark vertical and horizontal lines with a LASER level.
md2lgyk 01-14-2013 07:45 AM
It is more commonly called a china marker. Basically a pencil that's made with hardened wax instead of graphite. You can buy them anywhere office supplies are sold (even Wal-Mart has them).
mikegp 01-14-2013 08:17 AM
I just use a regular pencil and write lightly. Then use a new pencil eraser to get it off.
Also, are you using once of those fancy closet kits with a bunch of half shelves? I bought one and then realized it would take hours of work and actually yield less usable space. I ended up just buying a long shelf so my son's closet has two long levels. Much easier and better use of space.
DangerMouse 01-14-2013 08:51 AM
IF, you're just trying to line up where the studs are to attach the shelves to a strong backing, you could just use rare-earth (hard-drive) magnets to locate the studs (screws), like I do/did. It works just fine and leaves no mark.
DM
creeper 01-14-2013 09:03 AM
If you haven't purchased it yet, you may want to consider Rubbermaid Configurations instead.
I have installed both Closetmaid and Rubbermaid and the latter is much easier to install and I find in general just a better product.
Not sure why someone would suggest you have less use with those then just a regular system as I found the versatility offers a huge amount of storage space.
Even more than a custom closet with cubby type box shelves, even with adjustable height shelving
Adrenalinejunky 01-14-2013 11:28 AM
gently!
"RF"
What's with carpenter pencils not sharpening well, or the tips break off easily?
Arsinek 01-14-2013 07:52 PM
DM
I actually have something similar. Not sure theyre as strong as what youre using.
This is what I have...
http://shop.magicstudfinder.com/imag...-529188096.jpg
http://www.magicstudfinder.com/index.html
Works pretty well. But sometimes Ill find a stud and these magnets will only find like one spot to stick to, which theoretically would mean there are no nails in it. I also use a zircon stud finder with these magnets.
Click Plastics 01-15-2013 06:31 AM
i generally use a standard carpenters pencil, never had any problems!
