What Is This Pipe In Basement Closet? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-11-2011, 05:28 PM   #1
What is this pipe in basement closet?
Hey all,
I'm looking at purchasing a home. It has a basement. In one closet there is a PVC pipe, capped off about 4 ft off the ground. The closet has an electrical outlet on the wall next to the pipe. The closet wall are all internal. Anyone have any ideas? See the picture attached.
Thanks - Drew
zimaad is offline   Reply With Quote
Old 11-11-2011, 06:19 PM   #2
I would guess it might be for a radon system if it is needed. When I was in western NY one builder started putting them in just in case. It could also be for future plumbing.
Old 11-11-2011, 08:33 PM   #3
I thought it may be that, but it would take a WHOLE LOT of work to put a pipe to evacuate externally without it being designed into the house originally.
Could it possible be a sump pump of some sort? Are there any that don't have to directly pump outside via an external wall?
- Drew
Old 11-11-2011, 08:40 PM   #4
DIY staff
Rewards Points: 7,174
How old is the house? Could be a drain for a future bath upstairs---could be a stand pipe for a basement drain (I doubt that one)
Not likely a radon evacuation system--buy anything is possible.
Old 11-11-2011, 09:16 PM   #5
House was custom built in 2008. The closet is across the hall from an already finished bathroom in the basement. The rest of the basement is finished.
Old 11-11-2011, 10:22 PM   #6
Rewards Points: 5,336
Do you live in an area that has Radon issues?
Ron
B. Franklin 1759
Old 11-11-2011, 10:29 PM   #7
Not that I know of. I've lived here my whole life and never seen a radon system in a house. That doesn't mean they don't exist here, but I just haven't seen any!
hmmmmmm... I'm perplexed!!
Old 11-11-2011, 10:34 PM   #8
It would help if you mentioned where you live.
Ron
B. Franklin 1759
Old 11-11-2011, 10:50 PM   #9
Richmond, Virginia
Old 11-11-2011, 11:40 PM   #10
here are a couple of maps showing radon concentrations in the usa.
http://www.radon.com/maps/
http://www.epa.gov/radon/pdfs/zonemapcolor.pdf
virginia radon info:
http://radonease.com/
Leaking around old drain pipe in basement spg Plumbing 1 08-16-2011 12:27 PM
driving a pipe from basement to basement. forresth Building & Construction 9 04-25-2011 10:19 PM
Adding washer to basement with no way to vent drain pipe General Plumbing 6 12-26-2010 12:11 PM
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 09:49 AM
advice on cold water pipe in basement garage area cambie Plumbing 6 10-15-2008 02:29 PM
