What Kind Of Paper Trail Do I Need To Create? - General DIY Discussions - Page 4 - DIY Chatroom Home Improvement Forum
Old 05-21-2014, 10:09 PM   #46
Msradell's Avatar
Rewards Points: 138
It's probably too late now for a curing sealant to do any good. The majority of the water in the concrete will already have evaporated by now. Normally it's much easier and simpler to spray it on using a pump up weed sprayer.
Msradell is offline   Reply With Quote
Old 05-21-2014, 10:12 PM   #47
r0ckstarr's Avatar
Rewards Points: 2,008
What about something to keep oil spills from soaking in? Too late for that, because the instructions for the link above apply to old and new concrete.
r0ckstarr is online now   Reply With Quote
Old 05-21-2014, 11:20 PM   #48
Concrete & Masonry
Rewards Points: 542
Way to late for a curing sealant. We generally spray it on ASAP, like 1 hour or so after we broom it.
You can use a siloxane or silane sealer after 30 days or so. These are best applied with a garden sprayer IMPO. Just read the instructions carefully.
And, I buy all of my sealers through a ready mix concrete supplier............
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
r0ckstarr (05-21-2014)
Old 05-22-2014, 08:57 AM   #49
r0ckstarr's Avatar
Seeing as how it's too late for the Vocomp-20, are there any certain brands of siloxane / silane sealer that you reccomend?
I googled for "siloxane silane sealer" and found two brands. One is Eagle. The other is Siloxa Tek.
Tags
paper trail
Removing Old Stucco Without Damaging Paper greenfrog5 Drywall & Plaster 3 12-31-2012 10:33 AM
Roofing practices: hammering down old nails; new felt paper over old; wavyness drumbliss Roofing/Siding 19 11-09-2012 01:05 PM
How to properly seal cuts and damage to drywall paper? maxforwardspeed Drywall & Plaster 13 09-02-2012 09:50 PM
Skylight Install: How to Retrofit New Asphalt Paper? amakarevic Roofing/Siding 11 06-06-2012 03:01 PM
why does starter strip have glue on it if it goes on tar paper? KarlJay Roofing/Siding 4 11-24-2010 03:05 PM
