What Kind Of Paper Trail Do I Need To Create? - General DIY Discussions - Page 3 - DIY Chatroom Home Improvement Forum
Old 05-19-2014, 11:37 AM   #31
Ole Wood Worker
BigJim's Avatar
Rewards Points: 184
Did they back the truck on the rebar?
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 05-19-2014, 12:07 PM   #32
r0ckstarr's Avatar
Rewards Points: 1,994
No. Back wheels up on the street curb about 30ft from the driveway, and what they couldn't get with the truck, they used a bunch of wheelbarrow trips to do.
r0ckstarr is online now   Reply With Quote
The Following User Says Thank You to r0ckstarr For This Useful Post:
BigJim (05-19-2014)
Old 05-19-2014, 02:15 PM   #33
r0ckstarr's Avatar
Done. Ill have pictures of the final product this evening when the sun isn't so harsh.
I felt out of place. I am usually the one that does all of the work. At my job, i run the show. It was hard to not want to help. I had to keep telling myself that i am paying them to do this for me.
I still felt the need to be helpful, so i gave them cold water throughout the day, and really cold beer when they were done.
Old 05-19-2014, 10:53 PM   #34
r0ckstarr's Avatar
IMGP1753 by r0ckstarr2, on Flickr
IMGP1738 by r0ckstarr2, on Flickr
IMGP1731 by r0ckstarr2, on Flickr
IMGP1720 by r0ckstarr2, on Flickr
IMGP1718 by r0ckstarr2, on Flickr
IMGP1705 by r0ckstarr2, on Flickr
Old 05-19-2014, 11:15 PM   #35
Rewards Points: 1,188
It looks like the contractor did a Pro job, even cleaned up the area afterwards.
Did they give you instructions on curing this before driving on it, or moisture in the hot sun?
de-nagorg is offline   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
r0ckstarr (05-19-2014)
Old 05-19-2014, 11:22 PM   #36
r0ckstarr's Avatar
Yes, I can walk on it now as of 6pm, but cannot drive on it for 4-5 days. The longer I wait the better.
I think I will wait 2 weeks before pulling the big Buick out of the garage!
No need to water it down, because the temperature is cool enough that it won't evaporate the moisture out of it fast enough to crack it. He said if it were the middle of June, then yes, definitely water it down.
Also, they left part of the wood form on the inside curve of the walkway for the time being. He said he didn't want to take a chance of messing up the corner of the concrete, and would come back tomorrow to remove it.
Old 05-19-2014, 11:30 PM   #37
It is good to leave the forms a little while, because the edges cure faster and any weight will cause that edge to sluff off and ruin the beautiful job.
He was well worth the money.
ED
Old 05-19-2014, 11:31 PM   #38
r0ckstarr's Avatar
Thanks!
Old 05-20-2014, 09:47 AM   #39
landfillwizard's Avatar
Rewards Points: 502
When they finished the concrete, did they put any type of sealer on the surface?
landfillwizard is offline   Reply With Quote
Old 05-20-2014, 10:08 AM   #40
r0ckstarr's Avatar
No. Should there be? And is this a DIY item?
Old 05-20-2014, 10:16 AM   #41
Concrete & Masonry
Rewards Points: 526
Looks good from my computer.
Hopefully, they sprayed a curing sealant on it, the Texas heat can be hard on concrete curing.......
jomama45 is online now   Reply With Quote
Old 05-20-2014, 10:18 AM   #42
r0ckstarr's Avatar
High of 84 with 76% humidity today. Not as hot as it could be. No curing sealant sprayed.
Old 05-20-2014, 10:26 AM   #43
r0ckstarr's Avatar
Is there anything i can put on it to keep oil drips from cars, and other things from staining it up? I work on my cars, and sometimes spills happen.
Old 05-20-2014, 10:34 AM   #44
Concrete & Masonry
Rewards Points: 526
Here's some info on curing. Take a look at the chart to see the difference between curing and not. I'm in WI, and anytime it's over 50 degrees we use curing sealant because I realize how important it is. It's too darn cheap and easy not to. That said, it really should have had a curing sealant applied yesterday afternoon already, alot of free moisture has already been lost out of the concrete.
As for "which" sealers, i like to use a cheap water-based cure/seal, followed by a special siloxane (deep penetrating and great spill resistence) 30+ days later. Here's an example of the two sealers:
http://www.wrmeadows.com/vocomp-20-c...ling-compound/
Old 05-21-2014, 06:52 PM   #45
r0ckstarr's Avatar
Thanks for the information.
Apply VOCOMP-20 when the surface water has disappeared and the concrete surface will not be marred by walking workmen.
Am I too late for this, or just in time?
How have you applied yours? It says you can use a sprayer or a roller.
Where do you find VOCOMP-20? Does your local hardware store carry it, or does it have to be ordered from somewhere?
Tags
paper trail
Removing Old Stucco Without Damaging Paper greenfrog5 Drywall & Plaster 3 12-31-2012 10:33 AM
Roofing practices: hammering down old nails; new felt paper over old; wavyness drumbliss Roofing/Siding 19 11-09-2012 01:05 PM
How to properly seal cuts and damage to drywall paper? maxforwardspeed Drywall & Plaster 13 09-02-2012 09:50 PM
Skylight Install: How to Retrofit New Asphalt Paper? amakarevic Roofing/Siding 11 06-06-2012 03:01 PM
why does starter strip have glue on it if it goes on tar paper? KarlJay Roofing/Siding 4 11-24-2010 03:05 PM
