What Kind Of Paper Trail Do I Need To Create? - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-18-2014, 08:21 PM   #16
Rewards Points: 114
Recently poured cellar floor and driveway with mesh sitting on floor. As concrete is poured, mesh was just pulled up with a rake. Ron
ront02769 is offline   Reply With Quote
Old 05-18-2014, 08:36 PM   #17
Msradell's Avatar
Rewards Points: 90
And then when they walk over the concrete working it down the mesh again goes directly to the bottom! The only way to successfully use wire mesh or rebar if you set it up on chairs or some other acceptable device. If you pull it up you have no way to verify where it ends up, which is usually on the bottom.
Msradell is offline   Reply With Quote
The Following User Says Thank You to Msradell For This Useful Post:
kwikfishron (05-18-2014)
Old 05-18-2014, 09:27 PM   #18
kwikfishron's Avatar
Rewards Points: 90
Looking a little thin down the middle too.
kwikfishron is online now   Reply With Quote
Old 05-18-2014, 09:33 PM   #19
r0ckstarr's Avatar
Rewards Points: 1,980
How thick should it be all across? I can go measure and see what it is.
r0ckstarr is online now   Reply With Quote
Old 05-18-2014, 09:51 PM   #20
Rewards Points: 90
What does your contract say??? Should be 4" (3.5 min).
Old 05-18-2014, 09:54 PM   #21
r0ckstarr's Avatar
Contract doesn't specify thickness. I didn't know that was something it should have said.
Old 05-19-2014, 08:28 AM   #22
r0ckstarr's Avatar
I measured from the top of the wood to the sand.
On the sides, i have 4in all the way on both sides.
In the middle, i have different numbers. There's a section about 3 to 5ft diameter where the boards cross in the center closest to the camera, that it is 3.5in deep , then it gradually goes out from there to 5.5in thick as it nears the street. And, a liitle more than 4.5in thick at the garage foundation to the sand.
Old 05-19-2014, 08:52 AM   #23
Concrete & Masonry
Rewards Points: 470
Couple of things:
-That grading looks terrible IMO. I have no idea why they use sand, but the flatter the subgrade is, the better the slab will perform. I can't imagine they will use a wheelbarrow on that, they'd likely get stuck.
- That's not mesh, it's a tied rebar grid. Lot's of discussion about it here in the past, but I've seen adequate results in the real world from pulling it up during the pour. Those who insist a slab on grade needs to be chaired have probably never had to work around it. Or even torn any out themselves to verify where the rebar actually rests.
- The driveway should be a minimum of 4" everywhere IMPO....
jomama45 is offline   Reply With Quote
Old 05-19-2014, 08:57 AM   #24
r0ckstarr's Avatar
Well, my measurements are no longer valid. They're here right now making adjustments to everything and putting the rebar on chairs.
Old 05-19-2014, 08:58 AM   #25
Concrete & Masonry
Rewards Points: 470
Sounds good. Although I have a feeling you may just be saying they're using chairs to get the "DIY Police" off of your tail.............
Old 05-19-2014, 08:59 AM   #26
r0ckstarr's Avatar
Proof
What kind of paper trail do I need to create?-forumrunner_20140519_075941.jpg
The Following 2 Users Say Thank You to r0ckstarr For This Useful Post:
de-nagorg (05-19-2014), Msradell (05-19-2014)
Old 05-19-2014, 09:01 AM   #27
Concrete & Masonry
Rewards Points: 470
Do you know if they're going to pump the concrete in?
Old 05-19-2014, 09:02 AM   #28
r0ckstarr's Avatar
A cement truck is scheduled to be here in 1 hour.
Old 05-19-2014, 09:03 AM   #29
r0ckstarr's Avatar
I want the DIY police on my tail. Keeps me out of trouble, and teaches me what i didn't know i needed to know. =)
Old 05-19-2014, 09:31 AM   #30
Rewards Points: 780
That photo looks more like it.
Goes to prove the old adage: One should never ASSUME anything, if you do you make the first three letters in the word out of yourself.
ED
de-nagorg is offline   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
Tags
paper trail
Removing Old Stucco Without Damaging Paper greenfrog5 Drywall & Plaster 3 12-31-2012 10:33 AM
Roofing practices: hammering down old nails; new felt paper over old; wavyness drumbliss Roofing/Siding 19 11-09-2012 01:05 PM
How to properly seal cuts and damage to drywall paper? maxforwardspeed Drywall & Plaster 13 09-02-2012 09:50 PM
Skylight Install: How to Retrofit New Asphalt Paper? amakarevic Roofing/Siding 11 06-06-2012 03:01 PM
why does starter strip have glue on it if it goes on tar paper? KarlJay Roofing/Siding 4 11-24-2010 03:05 PM
