What Kind Of Nailgun? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-30-2012, 07:13 AM   #1
What Kind of Nailgun?
I'm going to be assembling a wooden shed once it gets delivered. I have been reading the instructions online and it calls for something like 250 6 penny 2" and and 950 2 1/4" nails and highly recommends a nailgun to save time. I've never owned a nailgun before and there are so many varieties it is overwhelming. Does anyone have any suggestions on what type I should get so I don't buy one that can't do the job?
Any help is appreciated!
crowbb is offline   Reply With Quote
Old 11-30-2012, 07:42 AM   #2
DIY staff
Rewards Points: 7,174
You are looking at a framing nailer---if you have a compressor---get a cheap air driven one---if you don't have one of those---seriously consider hand nailing it----that's a big tool expense for one project----
Old 11-30-2012, 07:55 AM   #3
Rewards Points: 13,764
Your looking for a framing nailer.
If this would be your only big building project just use a hammer.
To use a framing gun you also need a compresser unless you want to spend over $300.00 for cordless one.
If you plan on doing lots of projects and you have no air tools then concider buying the set, not just one tool at a time. With a set you can get the compressor and the differant nail guns at one time and save some money.
When researching a tool purchace I like to check out Amazon.com, pick a tool and go to the bottom of the listing to read the reviews from real people that have bought the tool.
I also go on CPO tools web site to check out the deals on recon tools.
Old 11-30-2012, 08:00 AM   #4
Rewards Points: 3,130
Cheap framing nailer? Don't think I've ever seen one of those. But a framing nailer isn't really a beginner's tool. Get yourself a good framing hammer and build the shed the old-fashioned way. I did all the framing on the house my wife and I built and that's what I did. Once you get the hang of using it, you'll probably be able to drive those small nails with a single whack.
The Following User Says Thank You to md2lgyk For This Useful Post:
oh'mike (11-30-2012)
Old 11-30-2012, 08:40 AM   #5
Thanks for the suggestions. It sounds like a framing hammer might be the way to go for me. I'm not inexperienced with power tools but I have not used air compressor driven stuff much.
Old 11-30-2012, 08:41 AM   #6
DIY staff
Yep---I was the last guy on the block to get nail guns----(I wouldn't go back to hand nailing)
Wore the waffles off a few hammers in the old days----
Old 11-30-2012, 09:02 AM   #7
Rewards Points: 5,974
There's always the option of renting gun and compressor for a day.
The Following User Says Thank You to ToolSeeker For This Useful Post:
Gymschu (12-04-2012)
Old 11-30-2012, 10:51 AM   #8
Special User
Rewards Points: 1,230
I've tried hammering long 6 penny nails by hand. Disaster! Maybe I just suck at it, but I split a lot of 2x4s and bent a lot of nails. And that's straight on, forget toenailing!
Then I bought a palm nailer. Those are great, because one palm nailer handles many different sizes and type of nails. I love my palm nailer for smaller nails, it's awesome for doing siding for example. But those darn 6p nails still bend, even with the palm nailer.
I gave up and went to screws. For long screws I use square or torx drive (Phillips tend to strip when you get into longer lengths). Screws zap right in faster than a hammer, suck parts together tight, and can be backed out if you change your mind. Screws are admittedly slightly weaker in shear, so for shear loads I just add more screws.
If I really wanted to use 6p nails instead of screws, I'd get a real nail gun. If you don't have/want a compressor, I think they make cordless piston nailers with a flammable gas cartridge and spark ignition when you pull the trigger? I've seen them on Hometime.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 11-30-2012, 11:07 AM   #9
bbo
i just bought a refurb framing nailer when I needed one. I knew the project was coming up so I kept my eyes out for a sale on the refurbs. money well spent.
word of caution, read all the literature and practice for a while on some spare 2x4s until you get the hang of it.
bbo is offline   Reply With Quote
Old 11-30-2012, 12:30 PM   #10
kwikfishron's Avatar
Rewards Points: 620
Makes me nervous when I see someone pick up a framing gun for the first time. Newbie on a table saw and a few other things gets antennas flying high too.
When I was the newbie kid on a framing crew it was quite awhile of just hand banging before the boss let me pick up a nailer. Then it was awhile of only being allowed to nail off sheathing before they let me start nailing studs and such.
There are certain people on this earth that may be brilliant at this or that but should never pick up a nail gun. Just saying…
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
oh'mike (12-01-2012)
Old 11-30-2012, 04:31 PM   #11
bbo
yep, safety should always be number one.
Old 12-01-2012, 11:19 PM   #12
Rewards Points: 1,092
what are you nailing w/ the 6 penny nails? i believe 8d is the recommended nail for 1/2" ply. maybe on a shed it matters not. a nail gun can be great, but you may find that you miss more than you hit with it. i had a new guy helping me, and i had to go around and hammer back out about 1/3 of the nails he shot through the plywood into studs.... or thereabouts. you have no "feel" with a nail gun. as others said, just get a hammer for one shed and have fun beating the living &*^% out of some things!
Old 12-02-2012, 08:18 PM   #13
I would suggest to go to a rental place and rent a Paslode cordless framing nail gun. You don't need a compressor, and since you have to have the nose fully engaged, much safer for the inexperienced. If you feel like it may not be a bad idea to buy a nail gun for future projects, go to Harbour Freight. Get a 20% off coupon online first!!
mknasa dad is offline   Reply With Quote
What kind of cable is this? Sith717 Electrical 3 03-10-2012 01:56 PM
What kind of valve is this? mwong Plumbing 10 12-06-2011 11:33 PM
what kind of wye do I need? graysqwrl Plumbing 6 06-22-2011 04:23 PM
Painting Baseboards(does it matter what kind?) SabineTLK Interior Decorating 12 02-06-2011 07:34 AM
painting over drywall -- what kind of prep? CindyF Painting 6 01-12-2006 12:54 AM
