Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 09-14-2012, 04:04 AM   #1
Question
What glue should I use on a bath faucet?
As title, a small part on the faucet fall of few days ago:
What would be best glue to use to glue it back? Thanks!
ohman is offline   Reply With Quote
Old 09-14-2012, 10:56 AM   #2
They're supposed to snap on or screw on depending on what style it is. The cap has to be removable for future service.
A tiny dab of clear silicone would hold it in place until you find a replacement cap.
Old 09-14-2012, 07:47 PM   #3
Thanks for your reply! So I assume that with clear cilicone I can still remove the cap later if I want to, right?? I don't see any screw beneath the cap but I guess you are right that it might not be a good idea to just "glue" it back... thanks!
Old 09-14-2012, 09:03 PM   #4
or use a small amount of plumbers putty for easy removal
allthumbsdiy is offline   Reply With Quote
Old 09-15-2012, 07:54 AM   #5
Household Handyman
Yes "ohman", there is a screw underneath the white porcelain cap with the black "C" imprinted on it. I can see it clearly in the photo.
Old 09-18-2012, 06:08 AM   #6
Jack of all Trades
lifestooshort81's Avatar
Silicone is an amazing sealant as well as an adhesive. It does take time to set so it's not great for certain uses but glueing the cap on is fine just use a small dab. Wipe and excess that's still wet with a mineral spirits soaked rag (it's the only thing that'll clean up silicone) or wait till it dries and mechanically remove it.
Once it's dry it's a flexible glue. This means you can pry the cap off if you need to access the screws below.
I'm not too find of plumbers putty. I always find stuff growing in it (mold and such).
Hope this Helps. I'm a contractor and do this stuff all the time...i use silicone for everything I can!
Al
lifestooshort81 is offline   Reply With Quote
The Following User Says Thank You to lifestooshort81 For This Useful Post:
ohman (09-18-2012)
Inline Bath Vent Switch Wiring Dano81 Electrical 3 05-09-2012 11:52 PM
Delta Bath Faucet Leaks rtrinkle Plumbing 3 12-13-2011 08:44 AM
Supply valve to bath faucet doesn't stop water Kurt123 Plumbing 2 09-05-2010 10:48 PM
Have you ever thing this bath faucet stem? Very rare. allen_91107 Plumbing 6 08-16-2010 09:54 AM
Single-handle Bath Faucet leak tystaylor Plumbing 4 04-07-2009 10:17 PM
