Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 08-25-2008, 08:49 AM   #1
What do you think about Double Glazing with plastic sheets?
Hi Everyone,
What do you think about double glazing with plastic sheet?
Is plastic window insulation kit a permanent double glazing solution?
It may be low cost, but are they suitable for all double glazing situations?
foster01 is offline   Reply With Quote
Old 08-25-2008, 05:12 PM   #2
Advice worth 2 cents!
My house is 102 years old and is on the national registry. My windows are all original. They are single pane and each window has two frames. In those days the cost of heating was nothing to consider so the gaps are quite large all around. I added a box casing that allows me to install a layer of plastic film. I buy the stuff that is "shrink-fit" and is practically invisible. I install all of them in an easy afternoon sometime in November and throw the stuff out in the spring. The cost is nothing compared to how well they work.
---pete
HandyPete is offline   Reply With Quote
Blue plastic receptical/switch boxes used as junction boxes? alexz Electrical 7 04-09-2013 09:40 PM
Corrugated plastic fixtures tonydee Roofing 4 07-16-2008 11:36 PM
How Does A Double Pole Circuit Breaker Trip? shadowx360 Electrical 2 07-09-2008 03:44 PM
Dual double or 1 double, 2 singles? pcampbell Electrical 7 03-25-2008 11:55 AM
Temporarily Replacing Double Glazing Unit kitefan Building & Construction 6 10-04-2005 02:05 PM
