What Do You Put Around A Door/doorframe To Keep Light From Coming In? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-08-2007, 11:01 PM   #1
Question
What do you put around a door/doorframe to keep light from coming in?
Hello there! I'm a newbie here and this is my first post and I have a question.
I rent a room in a house full of college students, and sometimes the hall light wakes me up because it comes into my room through the cracks around the door.
Does anyone have any suggestions on what to put around the door/doorframe to keep as much light out as possible? is there something I can buy at WalMart or do I have to make something myself?
Thanks!
xavierob82 is offline   Reply With Quote
Old 12-09-2007, 08:32 AM   #2
Eibwen
Some self adhesive sponge weatherstripping should keep most of the light out. Wal Mart or a home center should have it and its not expensive.
Sammy is offline   Reply With Quote
Old 12-09-2007, 08:47 AM   #3
Rewards Points: 26
Just like sammy said. Home depot has a ton of different kinds,sizes, and shapes. It's in the same aisle as the door knobs.
ponch37300 is offline   Reply With Quote
Old 12-09-2007, 03:43 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,712
After you close the door,......
Hang a Blanket over it,.....
It'll Stop the Light,+ cut down on the noise alittle.....
Old 12-09-2007, 10:07 PM   #5
Thanks! I used weather stripping like you all said around the door frame and portions of the door itself (to fill in the "gaps" of penetration) and my room is now as black as night! Its a practical darkroom. Heavenly!
Thank you!
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 09:44 PM
Part of a ceiling fan light fixture needs help...please g5729 Electrical 1 06-17-2007 06:22 AM
Red & Black wire from light = blown fuse leedslad Electrical 3 08-28-2006 06:54 PM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 07:11 PM
Replacing light killed downstream outlets, totally stuck amissner Electrical 5 07-13-2006 06:02 AM
