What Could This Material In Attic? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-19-2013, 06:49 PM   #1
What could this material in attic?
Hello I have this brown material sticking out of my attic latch and was kind of worried it could Brown Asbestos. I know that type was hardly used in the western world in homes ( well from what I read) and was wondering if I am over thinking it could be that material. I have 2 pictures if anyone could take a stab at what material this most likely is. I know you cant be 100% certain it is not asbestos without a lab test but that is the next step most likely.
[IMG][/IMG]
Thanks for any inputs.
Dan281 is offline   Reply With Quote
Old 02-19-2013, 07:00 PM   #2
Rewards Points: 12,802
Just looks like dirt and dust being sucked up toward the the access to me.
Old 02-19-2013, 07:06 PM   #3
It definitely looks like a brown material, going all around the attic door. Kind of looks like red scotchbrite but brown.
Old 02-20-2013, 01:26 AM   #4
Rewards Points: 626
OH NO Time to call the HAZMAT team in. Not looks like rock wool or just plain old every day cob webs and dust.
Nailbags is offline   Reply With Quote
Old 02-20-2013, 04:54 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 120
Open the stupid door and actually SEE what it is
Old 02-20-2013, 06:48 AM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 334
Ayuh,.... Looks like dusty cobwebs to me....
Old 02-20-2013, 02:18 PM   #7
Ambidextrous klutz
Leprechaun's Avatar
Rewards Points: 38
To me it appears someone put a fibrous material like some cheap padding on the back side of the scuttle cover. I agree that you should climb up and look at it -- and also check out the attic.
Cheers!
-Lep-
Leprechaun is offline   Reply With Quote
Old 02-20-2013, 05:04 PM   #8
PoleCat's Avatar
Rewards Points: 1,638
Cellulouse.
PoleCat is offline   Reply With Quote
Old 02-21-2013, 01:42 PM   #9
Biarski's Avatar
--Guessing it's old rock wool--had an attic full, just covered it with a layer of batts going opposite the joists except for the plywood storage plates covered in boxes of priceless junk-
Biarski is offline   Reply With Quote
Old 02-21-2013, 02:02 PM   #10
SuperJETT's Avatar
Rewards Points: 156
If you're that concerned, put a dust mask on and open the hatch up to see what it is. Even if it is asbestos, it won't kill you from touching it. The problem is inhaling it after it goes airborne such as from grinding/cutting.
Have you never been in your attic?
SuperJETT is offline   Reply With Quote
Old 02-26-2013, 02:50 PM   #11
Mold!! Let's kill it!
Rewards Points: 2,012
Looks like a felt weatherstripping material to me. Not likely to be asbestos.
Best material for attic access panel ADKMatt Insulation 3 10-25-2011 08:14 AM
Attic Insulation tim1218 Insulation 4 09-07-2011 11:18 AM
Ventilating attic with two roofs senorbungle Building & Construction 2 01-09-2011 05:17 PM
Frost in the Attic 295yards General DIY Discussions 13 12-07-2009 05:27 PM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 08:41 PM
