What Are The 'code' Space Requirements For A Toilet In A Three Walled Area?? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-19-2009, 10:06 AM   #1
Rewards Points: 562
What are the 'code' space requirements for a toilet in a three walled area??
So both front space and side space if anyone 'knows'. IF there is more than ONE code possible,,a quote from EACH!! Does a slanted wall alongside it, count as space ?? where then measured???
Where in a small old house is this magical space to come from??
4just1don is offline   Reply With Quote
Old 05-19-2009, 10:18 AM   #2
Oldguy
Rehabber's Avatar
15" on each side, 24" in front of toilet. check the brand of toilet for its dimensions as brands/models vary (especially the front)
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 05-20-2009, 02:01 PM   #3
Registered User
Rewards Points: 5,482
UPC (407.6) 15" clearance from center to side walls or other fixtures IRC [2705.1]
Minimum 21" [IRC] 24" (UPC) in front of [lav] toilet or bidet [2705.1] (407.6)
Be safe, G
Old 05-20-2009, 09:47 PM   #4
Old School
Willie T's Avatar
And, trust me, you'd better be one small dude to use a toilet so tightly wedged into that space.
Willie T
Old 05-21-2009, 08:18 AM   #5
Registered User
Termite's Avatar
In an old small house it is often impractical or impossible to maintain water closet clearances without serious modifications to the structure. For that reason I'd suggest contacting the inspector to "feel him out" regarding leniency. When meeting the code on an old home becomes impractical or impossible, there is often room for some negotiation when the issue isn't going to get anyone hurt or killed. The clearances around a water closet are not life safety codes, they're for usability. They're written for people with wide butts and/or long legs.
Old 05-21-2009, 09:32 AM   #6
Old School
Willie T's Avatar
Hey! Watch it! .......
Oh............ You also mentioned long legs. That's cool... disregard this.
Willie T
Old 05-21-2009, 09:40 PM   #7
Rewards Points: 562
I get the idea of the two axe handles wide hiney's that need some space. Do ALL houses have to be built for the obese??If a person was that large,my guess is they would have other issues as to whether they could rent a place!! Like a 24" doorway for instance. Arent those still legal for closets and baths??
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Attic Storage Space Above Garage sunthas Building & Construction 5 02-23-2009 12:18 PM
Sealing the space between the toilet and the floor... pro_DIYer General DIY Discussions 4 07-11-2008 01:25 PM
Need opinion - Need help - I believe my toilet was not installed properly rdlegacy Plumbing 9 05-06-2008 05:03 PM
Crawl Space In Basement -- Please Help thekid Building & Construction 7 01-04-2008 08:15 PM
