What Is This Called??? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-23-2008, 02:53 PM   #1
freshman
Pipeline's Avatar
what is this called???
I'm dum
Would like to know the name of this little thing
My screen door itself will not stay open when I position this thing all the way...
I'm thinking I need a one of these small things
Pipeline is offline   Reply With Quote
Old 11-23-2008, 03:01 PM   #2
Rewards Points: 6,652
Quick answer, a Piston stop. They are in the same aisle as Screen door hardware items.
Old 11-23-2008, 03:03 PM   #3
freshman
Pipeline's Avatar
thanks!!
I hope your right about this in the same lane as screen door kit but I only want the [now I know!] piston stop, not the kits costing $13 bucks
Old 11-23-2008, 03:15 PM   #4
You do not need to purchase the whole piston kit, unless the piston is bad, then it is a good idea. The stops are usually avail. @ any hardware store, or Ace Hardware.
Old 11-23-2008, 03:27 PM   #5
freshman
Pipeline's Avatar
you mean if the door keeps sliding back -it will only go back 1/4th but not all the way-then i need more than a piston stop????
Old 11-23-2008, 03:44 PM   #6
The piston stop is set to keep the door closer from causing the door to close. If it is not working properly, one reason can be that the closer is set for too much force, or the piston is shot and needs replaced.
Old 11-23-2008, 03:55 PM   #7
freshman
Pipeline's Avatar
it started to malfunction one day and I thought it was a set way to turn the stop and stay but over time that is not the case[in the 1st place it worked perfectley and no one has adjust the force.
the piston stop is worn down
so that is what I want is another piston stop, not the whole kit
will that work?^^^
Old 11-23-2008, 03:56 PM   #8
Will not know if it works, until you stop replying and go to the store to pick up the parts and replace. For the time it takes to ask here and get a reply, you could of had the job done and gone on to do something else.
Old 11-23-2008, 04:22 PM   #9
the Musigician
DangerMouse's Avatar
put it in a vise and hit it with a hammer to bend it tighter. works every time.
DM
Old 11-23-2008, 04:23 PM   #10
freshman
Pipeline's Avatar
yea know what you mean
if a simple part like piston stop can be sold by itself great if not what a waste... other parts of the storm door gear is working fine.
got two kids at home and one is grounded so can't do too much out of the house
Old 11-23-2008, 04:27 PM   #11
the Musigician
huh? put it in a vise and hit it with a hammer to bend it tighter.
DM
Old 11-23-2008, 04:42 PM   #12
freshman
Pipeline's Avatar
I use the vise grip and hammer
that will not work and too much force will break the whole unit
time to hit the hardware section
Old 11-23-2008, 04:55 PM   #13
the Musigician
i've done it a few times and it always worked. one gal's was missing, so i made one from a washer.
DM
Old 11-23-2008, 06:37 PM   #14
Advice worth 2 cents!
Rewards Points: 150
13 posts for one of the most insignificant pieces of hardware in a house! (but still kinda interesting)
-pete
---pete
HandyPete is offline   Reply With Quote
Old 11-23-2008, 08:26 PM   #15
freshman
Pipeline's Avatar
Handypete
It gets more interesting!
I went to Lowe's and look for the piston stop - nope only in kits [range $8 to 13 bucks].
However, I did get a window lock - the piece that you simply clamp down on a pipe or tube [cost was $0.85 cents].
One tiny tiny problem.... it is bout 1-2 CM too tight - the window lock!
DANG!
I'm gonna see if there's window locks another 2 CM wider to be able to insert the clamp...
Stay Tuned
I Called a Plumber, Now I really need Help! kswoot Plumbing 8 10-14-2008 08:57 PM
what is this thing called? farag Plumbing 4 07-28-2008 09:36 PM
Flooring vs Subflooring (whatever it is called) lifeontherun Flooring 3 07-13-2008 04:03 PM
Flooring vs Subflooring or whatever it is called lifeontherun Flooring 10 07-09-2008 09:14 PM
What is this part of the gutter called? DanBress Roofing/Siding 4 11-04-2007 08:41 PM
