What Bonding Agent For Cement Over Flashing ? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-28-2013, 09:17 AM   #1
CDO
CDO's Avatar
Put this egress window in basement. Installed in a hole I cut in concrete block. I flashed with Protecto self adhesive flashing. How can I skim coat over this flashing? Any suggestions would be appreciated.
CDO is offline   Reply With Quote
Old 03-29-2013, 08:34 AM   #2
PoleCat's Avatar
Rewards Points: 1,652
That stuff is pretty smooth for cement to stick to. I think I would trim it out with pressure treated deck board. Looks like your foundation has been painted already. That might cause some trouble too.
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
Windows on Wash (04-02-2013)
Old 03-29-2013, 08:40 AM   #3
Rewards Points: 14,294
Poles right, not going to stick.
I'd use 1 X 6 vinyl lumber instead of the deck boards though, deck boards are not below grade rated and you would have to wait about 6 months for them to dry out.
You can attach them with Tap-Con screws.
You are going to add a window well, right?
http://www.bilco.com/foundations/sto...asp?nav=10*130
Old 04-02-2013, 07:20 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
These guys both nailed it.
Nothing is going to stick to that protecto wrap in terms of anything masonry.
Wrap it with PVC lumber and be done with it.
Repair or Replace Roof-to-Wall flashing Learn as i go Roofing/Siding 9 09-25-2014 11:53 AM
Re-roofing: flashing question prb_nearnorth Roofing/Siding 9 04-30-2012 11:42 PM
Tammsweld bonding agent heinlein0311 Concrete, Stone & Masonry 0 04-08-2012 06:50 PM
sister wall against old stone foundation - bonding agent? tcook555 Concrete, Stone & Masonry 3 03-16-2012 08:23 PM
mortar liquid bonding agent question drewhart Building & Construction 5 11-06-2008 07:45 PM
