What Is Around My Lower Basement Walls - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-30-2011, 05:37 PM   #16
All the newer homes being built in my area are insulated in much the same manner.
In my 1948 home, I just finished installing what the manufacturer has labeled as 'Foundation Blanket'.
Mine came in a 100' roll and the insulation was 4' wide (high?) The vapor barrier has a 12" apron (skirt?) at the top that is stapled over the rim joist cavity.
At the bottom is a steel strap. I drilled holes in this and screwed it to the foundation.
In the area where I have my office/computer room, I framed up a stud wall in front of the blanket, to mount the drywall and mount the utility outlets.
Fountains of Water Pouring Through Basement Walls dlr1200 Building & Construction 16 11-09-2010 08:15 PM
vapor barrier plus inside the basement when walls are sealed with a penetrable sealer concrete walls myhouse2010 Building & Construction 1 10-18-2010 12:35 AM
basement walls dorcutt General DIY Discussions 8 03-24-2010 03:43 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 05:44 PM
Painting Basement Floor and Foundation Walls meth Painting 5 09-26-2008 08:54 AM
